Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Couple HSR questions
Old May 10, 2006 | 03:06 PM
87RedGTA's Avatar
Car: 1987 Trans Am GTA
1. Has anyone had significant hood clearance problems with GTA hoods with this intake? Like i mean that with no bracing at all i still can't close the hood. I'd prefer not to have to cut a whole in it, but i can't really afford a new one right now, and i'm not driving around for months without one.
2. My primary fan will not turn on at all even with the sensor hooked up. I have a new 160 thermo but the thing will overheat completely with no fan action. I haven't run direct current through it yet to test, i was just wondering if anyone else knows why it wouldn't work.
Old May 10, 2006 | 09:26 PM
JayBoCC2's Avatar
Car: '88 trans am GTA
Engine: 5.7L 355 TPI L98
Axle/Gears: eaton posi 3.73 gears
2> check your fan relays they could be shorted out or fuses blown
Old May 11, 2006 | 08:42 AM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
With mine, I started by having 1/4" milled off the top of the intake. (To clarify roughtly 1/4" off the top of the BASE intake- not those fins on the top.) I got it so a measured height of 9 9/16" from bottom to top.
I am hoping to have it installed this weekend/mid next week.
I may wait for the long tube headers to come in, I might not.
But from everyone else with the 'bird install they just had to cut some hood bracing/insulation and that was it. I am hoping to not have to cut anything since I did that, but I'll see.
Old May 11, 2006 | 12:39 PM
87RedGTA's Avatar
I'm testing the fans today just hooking them straight to the battery and see if they go, then i'll go from there. And with the hood clearance thing i think i might have to go ghetto and just cut a whole in it for now, cause it's definitely not clearing without serious modification to the intake. It definitely sits higher than the fenders from a side view. I'll let you know what i do.
Old May 11, 2006 | 12:44 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Do you have pics of the HSR without the hood on?
I am go HSR and I will probably have the same problem.
Will lifting the back hinge bolts help get more clearance?
Old May 11, 2006 | 05:26 PM
87RedGTA's Avatar
No pics yet no, i'll try to remember to take some tomorrow of a side view so you can see the trouble that i'm going to have with fitment.
Old May 12, 2006 | 05:09 PM
87RedGTA's Avatar
So i just tried hooking both fans direct to the battery to see what happens and they both spin up with no trouble. Now i'm just confused, cause neither one turns on when the car is running. I know that the one is from a sensor that doesn't go into the new heads, so that i understand. I thought that the other was done by the computer, and that should all work just fine. Is there some relay i should be checking to see if it's burnt out?
Old May 15, 2006 | 12:18 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
could be a fan relay problem...as far as the clearance im not sure but on my camaro i had to dent a part on my hood to clear my CAI hose clamps.
Old May 15, 2006 | 12:53 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I don't have a direct side shot of mine, but I'll see if I can remember to shoot one tomorrow.
Old May 17, 2006 | 09:53 PM
Zepher's Avatar
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
ASE doc
Aug 25, 2015 09:14 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
