Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Will These Gaskets Work With Accel Base?
Old Oct 11, 2006 | 12:45 AM
Pat Hall's Avatar
I have a comlete SuperRam setup, but I want to start out just using the Accel base manifold with stock tpi ported runners and plenum. I was thinking of ordering the large LTR gaskets that TPIS sell. The stock style tpi runner gaskets just barely cover the ports on the Accel base, so I'm thinking the larger TPIS would seal better. Does anyone know if these gaskets will work okay with the Accel base and stock style runners? Thanks in advance.
Old Oct 11, 2006 | 04:02 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
You probably need to confirm this, but I think the large LTR gasket runners just have a bigger hole in the middle of them for the larger sized holes in the runners.....
Old Oct 11, 2006 | 11:15 PM
Pat Hall's Avatar
I'm just going on what I've read here on the message threads. According to most that I've read, supposedly all three of the aftermarket bases have identical runner port sizes (Edelbrock Hi-Flo, TPIS Big Mouth, Accel), so I figure if that's the case, then the gaskets TPIS sell should work with my Accel base. Hopefully somebody can chime in that's tried this. Heck, even if they don't work for some reason, I'll only be out $23 for the set. Thanks for the reply Vern!
Old Oct 18, 2006 | 09:24 AM
vernw's Avatar
I hadn't picked up on that for the bases. Might be nice to know if it's correct.
Old Oct 18, 2006 | 01:24 PM
Guest
Guest
Posts: n/a
I'm running a ported (to 1.75") Edelbrock base with factory runners and I'm pretty sure I used the stock gaskets.
Old Oct 19, 2006 | 03:14 AM
Pat Hall's Avatar
Hey Max, my intentions are to try and open up the factory runners enough at the ends to match them up to the larger ports on the Accel base. So if I used the factory gaskets, it'd cause a restriction between the base and the ends of the runners. That's why I want to try and use the TPIS large gaskets. Hey Vern, once I actually get my hands on a set, I'll post back and let you know if they work out ok.
Old Oct 19, 2006 | 10:03 AM
vernw's Avatar
Great, Thanks!!!
Old Oct 19, 2006 | 10:30 PM
Guest
Guest
Posts: n/a
Ahhh, I see. That makes sense.
1992 Trans Am
May 10, 2023 07:19 PM
tazs2000
Jul 15, 2017 08:44 AM
NinjaNife
Aug 23, 2015 11:49 AM
89-S-dime
Aug 12, 2015 11:57 AM
marcusaw
Aug 10, 2015 08:13 AM
