Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Will this TB work with an HSR???
Old 04-05-2007, 11:08 PM
ultimatefighter's Avatar
Car: 1992 Z28
Axle/Gears: 10 bolt posi. G80
BBK Power Plus Series, twin 58cc throttle body. Part # is BBK-1544. Will this work, if not, what would work better. Also, what fuel rails? I am ordering the HSR setup tommorrow or Saturday. So some fast help would be GREATLY appreciated.
Old 04-06-2007, 09:07 AM
jjvette's Avatar
Car: 89 vette
Transmission: a4
Re: Will this TB work with an HSR???
I am running the summit twin 58mm on my HSR. Very good quality and the price was right. I don't know how much the BBK is but you might save some bucks. Either way you go, make sure the throttle linkge is adjusted correctly so you obtain wide open throttle and no sticking at idle.
John
Old 04-06-2007, 07:29 PM
Car: 1992 Z28
Did you have any problems with the fitment under your hood with the HSR? Thanks for the Summitt tip, i will look into those as well.
Also, what injectors are you using? What fuel rails? Lastly, what kind of performance gain did you notice with your set up? Thanks
Last edited by ultimatefighter; 04-06-2007 at 07:33 PM. Reason: Automerged Doublepost
Old 04-06-2007, 09:21 PM
jjvette's Avatar
Car: 89 vette
Transmission: a4
Yes. The plenum that comes with the HSR is too tall for a stock corvette hood. I purchased a modified plenum for it. I am running the FMS 24lb/hr injectors with the HSR fuel rails and regulator.
I can't really say gains because I never raced it after I tuned it. I had a long runner modded 350 tpi that went a best of 12.79@105. I put the HSR on and went 13.10@107 but it was really lean. I will say even though it slowed down that I really like the HSR set up.
I have since installed a 383 with trickflow heads and have gone 12.16@112 It was also lean. I then dyno tuned it and had a base of 318rwhp. Two hours later after richening it up it was 342rwhp. I could probably pick up another 10or so with some more fuel. So I figure it'll run 11.80-11.90 now.
I just purchased a nitrous kit for it. I'm shooting for 10's.
Good luck with yours!
John
Jake_92RS
01-28-2020 10:37 PM
ASE doc
08-25-2015 09:14 AM
355tpipickup
08-19-2015 10:02 PM
Fronzizzle
08-17-2015 02:52 PM
355tpipickup
08-13-2015 07:35 AM
Quick Reply: Will this TB work with an HSR???
