Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR + poly engine mounts = can't use stock hood
Old Jun 16, 2008 | 05:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Just finished my 383 HSR build and wanted to point out a piece of information I've learned.
I just did a zero decked block 383 with my old HSR but with holley's 58mm TB. I added energy suspension poly bushings in the engine mounts... no other changes. Last time on my L98 with standard deck of 9.025 and stock old mounts, i had to cut just a tiny piece of bracing out to clear but it cleared and shut well.
Hood does not come near shutting now. SO i cut out all the bracing around the front of the plenum and throttlebody. I used clay to tell me what was goin on under the hood. I found all the spots it was hitting and cut that bracing out.
It will close, but only when you force it down. its hitting the TB/front plenum ribs. It bulges the hood up 1/2 inch or so. Basically it looks like crap when you FORCE it all the way shut so now i'm gonna get a new hood. no big deal, always wanted one and its much lighter than stock
BUT, this time i used felpro intake gaskets which raised the manifold up a tiny bit...probly .100 inch or so, judging by the thickness of the manifold gasket and the gap it left on the china walls. I have a oil leak now out the back wall, so i'm going back to the RIGHT STUFF gasket maker i used last time with great success, so MAYBE that i will eat up alittle clearance but i doubt its gonna be that much.
The car is a 89 camaro irocz, with factory Irocz hood. Beware of poly mounts and HSR on stock hood cars. Doesnt always clear camaros
Old Jun 16, 2008 | 05:36 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: HSR + poly engine mounts = can't use stock hood
Thanks Orr. Probably a worse condition on Firebirds.
Old Jun 16, 2008 | 08:23 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Thanks for the info
Old Jun 16, 2008 | 10:16 PM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
I used poly mounts on mine as well, hood wasn't shutting that well with aftermarket summit radiator (it was taller and made the snorkel sit higher and hit the hood) so I put washers around the hood-hinge bolts and made a temporary fix. Didn't try cutting the bracing, but I figure it wouldn't completely solve the problem, either.
Old Jun 17, 2008 | 06:12 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
There is a big chevy/camaro show this weekend at carlisle pa. I will be going and looking for hoods
Old Jun 17, 2008 | 10:53 AM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
This is the first Ive heard of fitment issues on a Camaro. Ive heard of them on T/As, but Ive always heard that theres little or no problems with Camaro hoods. Good to know though. I just put in poly mounts, and Im about ready to bolt up the stock hood Im like you though, Ive been wanting to get me a Jongbloed, so all may not be lost
Old Jun 17, 2008 | 03:48 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Wow, as soon as I saw this thread it was a flash back. I remember reading about the HSR fit issues when it first came out, it only barely fits under stock camaro hoods, and never with poly mounts. As for firebirds I was lucky enough to get it to fit on mine, but I think that was do to worn out engine mounts.
At this point I thought it was fairly common knowledge.
Old Jun 17, 2008 | 04:00 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i thought it was a myth that poly mounts raised the engine
Old Jun 17, 2008 | 09:41 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Might be time for a Proflow intake
http://www.edelbrock.com/automotive_...xt_chevy.shtml
Old Jun 17, 2008 | 09:44 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
thats an option for me, i may try that out...but then again, i kinda like my stealth ram and think a hood is a good bet mainly for weight reduction
Old Jun 18, 2008 | 01:37 AM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
I always thought the hood not fitting after a motor swap was a good problem to have.
Old Jun 18, 2008 | 08:29 AM
spills's Avatar
Car: 89 RS
thats pretty schweet, first time Ive seen that. Looks like it takes an LS1 TB, but everything else is for genI SBC
Old Jun 18, 2008 | 10:19 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Have ya heard the one about ....."if it has **** or wheels" you're going to have trouble with it?
Add Edelcrock to that!
Old Jun 18, 2008 | 09:36 PM
Tony89GTA's Avatar
Car: 89 GTA
Yeah aparently you can just order up the intake itself and fuel lines and from what I read on here you can rewire a LS1 throttlebody to work with our computers. The only shitty part is the intake is setup for pre 87 blocks but they do have one for vortec style heads.
Old Jun 18, 2008 | 09:42 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i'll have to get a pic of my hood bracing mods and my hood shut. it does shut but its resting hard on the TB/air intake boot clamp boot and i do believe it touched the plenum rib
Old Jun 19, 2008 | 05:13 AM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Do you think the ASCD SS hood would clear everything with the poly mounts? I've seen a few pics and it looks as if the underside has a lot more room underneath where the bracing is at on our stock hoods.
Old Jun 19, 2008 | 06:22 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i may find out i'm deciding on the SS hood or 2-2.5" cowl from up22 or glasstek
from the many pics of the SS hoods, i feel it will clear my problem areas with no trouble. I know the little cowl will definately help
Old Jun 19, 2008 | 01:30 PM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Here are the only pics I've found of the underside.
Attached Thumbnails HSR + poly engine mounts = can't use stock hood-ss_bottom1.jpg   HSR + poly engine mounts = can't use stock hood-ss_bottom2.jpg
Old Jun 22, 2008 | 07:17 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My friend ran into that problem today, poly mounts, HSR, and a big TB.
Also, poly probably doesn't raise the motor, it most likely puts it back into the stock location. the rubber ones wear out over time and the motor sags down.
I've got probably 2 to 3" of clearance under my RA1 hood.
Old Jun 22, 2008 | 07:38 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
well i've driven the car around alittle and i'm not sure if the heat cycling helps or not, but i think the motor has snuggled down into the bay alittle bit as the hood 'APPEARS' to have gained abit of clearance. It shuts like before, but doesnt appear to be resting as much on the TB and such underneath.
I havent checked it all with clay, but it appears to be shutting better and not buldging in the middle like it did before
Old Jun 22, 2008 | 08:15 PM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
I went ahead and ordered the SS hood from Hawks last thursday. I'll have some clearance measurements once I get it on the car.
Old Jun 22, 2008 | 08:45 PM
spills's Avatar
Car: 89 RS
I know the Jongbloed hood (now they changed the name to the Sunoco hood ) was made for carb'd cars, but I wonder if anyone has put one on a HSR car? Im debating between the SS and Jongbloed, so if anyone's got the Jongbloed please take some measurements for me, or elaborate on any fitment issues
Old Jun 22, 2008 | 09:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i beleive the clearance issue i have is only .25 inch or so..if that now. i believe most any cowl will be more than enough to fit HSR and poly mounts
The ss hood i havent seen in person, but from the many pics of it, and judging where the hood starts to rise up an inch or so, i believe it will clear the HSR/TB area just fine
I did not find any hoods for sale at the GM nationals so i'm gonna hold off on the hood for now since the stock one is fitting better..its not off by much.
i wish someone made a fiberglass iroc hood. I love this darn hood! even one with 1inch rise, sorta like the daytona/turbo hood i think it is, but without the goofy looking side slots and not quite as high
Old Jun 22, 2008 | 11:15 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
[thread hijack]
Never heard of that before. Does it use all GM sensors like the SR? Says 90mm TB. Is that an LS1 style? Proprietary fuel rails or stock or what? Interesting...
Frozer!!!
Jan 19, 2024 04:55 PM
ASE doc
Aug 25, 2015 09:14 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
