Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR hood fit question 88 GTA
Old Jul 10, 2011 | 05:59 AM
Igorealfast's Avatar
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
I have an 88 GTA. Will my HSR fit under my stock hood?
Old Jul 10, 2011 | 06:36 AM
bonesbrakr's Avatar
Re: HSR hood fit question 88 GTA
if you search you will find the answer... been answered MANY times before.....
Old Jul 10, 2011 | 07:13 AM
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
New to this site. I'm learning to navigate and search. Finding answers are not that easy.
Old Jul 10, 2011 | 07:54 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Don't worry I get sick of people to, boosting their post counts saying go search this site can be a pain to look stuff up sometimes but it's better then most I been on.
To answer your question though, I have heard you can do it if you cut your bracing off from under the hood, still it's pretty close. Years back I bought a HSR to for measurements and found with my ES poly engine mounts there was no way I could pull it off, guess you would need the stock saggy engine mounts in the car to really do it.
Old Jul 10, 2011 | 08:39 PM
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
Thank you! I'll try the bracing, otherwise it's a WS6 hood for me.
Old Jul 10, 2011 | 09:47 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
this site is excellent search wise compared to many other forums
Old Jul 11, 2011 | 02:56 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I will 2nd the search. The information is there.
I just did a quick search for "HSR Firebird Hood" and wala.
https://www.thirdgen.org/forums/alte...clearance.html
https://www.thirdgen.org/forums/tpi/...clearance.html
https://www.thirdgen.org/forums/body...d-modding.html
Old Aug 26, 2011 | 10:38 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm bringing this back up. I've done the search, looked at the pics, and I still have a question. Has anybody determined specifically WHAT hits the hood? Is it the leading edge of the plenum, is it the throttle body, or is it both? I'm once again toying with the idea of getting a stealth ram, but this time for my GTA instead of my IROC. I have no desire whatsoever to cut the hood or to go to an aftermarket one, so I'm instead trying to decide if I want to modify the HSR, but that will largely depend on what's interfering with the hood. Based on one pic I found that Zepher posted, it would seem that both the front of the plenum and the throttle body stick up above the hood line, but they're so bad in his pic that it gives the impression that you'd need to lower the plenum & throttle body an inch or more to get it under the outer hood skin, which we all know isn't the case.
So... has anybody determined what's causing the interference?
Old Aug 26, 2011 | 10:43 AM
conlinj's Avatar
I know the mounts have a lot to do with it too, on my camaro with poly engine mounts even with the bracing removed it was not going to clear. Same on my friends GTA with the poly mounts.
-Jim
Old Aug 26, 2011 | 11:40 AM
-Jim
Its the Throttle body.
For mine, the fit was exceedingly tight, but all I had to do was put the metal screw clamp upside down and it fit, but rubbed the insulation.
The lowest point of the hood is the furthest point forward on the HSR. You may need to clear more than that in some cases depending on the mounts.
Old Aug 26, 2011 | 07:51 PM
Jim85IROC's Avatar
The reason I ask is because I'm tinkering with the idea of getting one and making an angled adapter that will tip the throttle body down, but that would be for nothing if it was the front of the plenum that hit. Hopefully my 150k mile factory mounts will allow for extra room.
Old Aug 26, 2011 | 08:02 PM
I also had indents of the TB top plate into the insulation. So you may run into issues there.
Old Aug 26, 2011 | 08:35 PM
Jim85IROC's Avatar
I don't really care about indents in the insulation... I just don't want to cut up the hood.
Old Aug 27, 2011 | 06:29 AM
conlinj's Avatar
good luck lol, have you considered using a 4bbl style intake with an elbow and ls1 style throttle body? Doesn't really give the same look as the stealth ram but you should be able to get the elbow to clear easier.
-Jim
Old Aug 27, 2011 | 10:07 AM
Jim85IROC's Avatar
I've given it some thought, but from what I can see, they seem to rob too much low end torque than I'm willing to give up in this mild 350.
Old Aug 27, 2011 | 11:25 AM
conlinj's Avatar
That's funny I would have thought it to be the opposite if you used with with a dual plane manifold, since the HSR is basically a tunnel ram. I have the HSR on my camaro now, I'm very happy with it but I think if I had it to do over again I probably would go with an elbow type setup.
Old Aug 27, 2011 | 11:51 AM
Jim85IROC's Avatar
I'm not aware of many (any?) dual plane intakes with injector bosses.
Old Aug 27, 2011 | 12:10 PM
conlinj's Avatar
My mistake, just went and looked at the pics of the car and it was a single plane. I saw a setup being installed on a car and thought it was a dual plane. I guess the only was to use a dual plane style intake is with the ez-efi setup.
Old Oct 3, 2011 | 05:36 PM
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
Well folks, my HSR does indeed fit under my stock hood with no issues. All I had to do was trimm the bracing, and it's just perfect. Bye the way a "Big Thank You" to everyone. The 383 fired up and ran today. All I can say is wow....this thing is just plain evil...but in a really good way.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
bryan623
Aug 10, 2015 11:33 AM
