AFR 210's, Mini-Ram, 355 N/A
Car: 1991 Z28
Engine: 350 TPI RAMJET COMING
Anybody using AFR 210's on a 350 with a mini-ram? That's my next plan. Curious about real world experience. I'm want to use a manual trans and 3.73/4.10 gear........
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: AFR 210's, Mini-Ram, 355 N/A
I used to use the 210cfm with 75 cc CNC heads part number was #1100 on a 355 with a Vortech Supercharger and ran into a ton of issues with tuning. I now have a 434 CID and just torqued the heads down tonight. I just unboxed the TPIS intake and it is a TPIS II system.. Some kinda upgrade. I am seriously going to see my TPIS I system as I don't have a need for it any more and it is going to sit around and collect dust.
Engine: 4++,350 & 305 CIs
I ran that combo b4 but was a 89 350 auto. Went mid 11s on stock tune. Would have gone low 11s with a tune I'm sure.
I won't put less than a 210 head on any EFI 350..
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
210 street or comp port?
210 is plenty for a 350 how high are you going to rev it?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Im running AFR 235s on my N/A 400 stroker and wish I could get a 260-270cc 23* runner from afr. Prolly hit up the 18-15deg or SB2 stuff next
We'll have to line em up some time
Axle/Gears: 4.11
Think a 195 c port will get you there
210 c port will take a healthy 383+ there for comparison
Ive always used heads a little on the large side but am only interested in WOT/strip performance. You use/drive those a lot different with not quite the expectations of manners on the street. Buy the head for your build you have NOW....this buying too big and growing into later business will **** you off on your "now" build.
Opinions will vary
Opinions will vary Thread Starter
Car: 1991 Z28
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
I'm putting together something similar. 358ci all forged. Fast burn heads, zz409 cam 1.6 rr. 10.2 to 1 cr. my original intent was to run a miniram but wondering if I should consider another converted carb style manifold? I'm open to suggestions. Maybe my best bet is the miniram. I've done a search and it all seems to depend on setup and combo. Just looking for some info from people Thant have been there. Thanks
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Afr 195 can support 7000 in a 350 but i would use the 210 if your hp peak is gonna be over 6500 rpm. Its not too much head. Afr's have a small csa for the runner size and are a fast velocity head compared to other similar cc heads out there. If you are making power to shift at 7k you are not worried about whats under 4k rpms lol
1989gtatransam has ported afr 222 cc on his 369" sbc revving to near 7k with peaks in the 6600 range
codeysabatini
Nov 10, 2015 04:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
355tpipickup
Sep 28, 2015 05:50 PM
