383 SBC with HSR - is this normal?
Car: 1985 IROC-Z
Engine: 383
I haven't driven my car a ton since I finished the install, but I noticed that anytime I go to get gas, it's really hard to get the cap off and once I do, you can hear a ton of air moving (not sure if in or out). Is this normal for a fuel injected 3rd gen? If not, will this cause problems?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 383 SBC with HSR - is this normal?
Check your tank vent. Do you have the evap charcoal canister still operating?
You will get some pressure in tank but i dont think it should be excessive
Car: 1985 IROC-Z
Engine: 383
How do I know if it's operating? It's still there and hooked up (as far as I know), is there a way to tell if it's working correctly?
Car: 89 Iroc-z
Transmission: TH400
Is all the lines and sensors still hooked up with the hsr swap?
Car: '91 RS / '17 FiST
Engine: Internal cumbustion
Transmission: 1 with a fun pedal and 1 without
Axle/Gears: 4th gen ss
Maybe I'm mistaken but I thought the tanks in these cars weren't vented? I know mine will build some pressure and give me a little purge sound when I unscrew the cap, but nothing major.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Ahhh, I was trying to figure out what the 'P' could be lol.
Car: 89 Iroc-z
Transmission: TH400
On my 89 there is also a line leading into a ball valve looking thing that functions as a tank vent.
https://www.thirdgen.org/forums/post...970-post6.html
Engine: Lb9
Transmission: M20
That is a vent valve , I'm not sure why they didnt use a vented gas cap but its a one one check valve to allow air into the gas tank.
Engine: Lb9
Transmission: M20
Car: 89 Iroc-z
Transmission: TH400
Its a one way valve into? Mine always made a leaking out sound after parking it after a long hot drive. I thought it was a pressure regulated vent valve for letting air out the tank, but then fumes would be an issue and i never did smell anything.
Then again i dont run any charcoal canister purge system and have my tank open to atmosphere and dont have any issues either
Engine: Lb9
Transmission: M20
Im not sure The one on the link I gave away I could suck through it but could not blow through it . Just assumed thats how it worked.
Car: 1985 IROC-Z
Engine: 383
Well...my canister is still there but I have no vacuum line going to it, or to anywhere in that area. Like Orr89RocZ, I have that little vent that is hooked to a line near the tank, but again nothing up front is hooked to vacuum. I overlooked this as I had a lot of problems with the engine at first, I disconnected everything including the cruise control and just never ran a vacuum line back.
So, my question now is (1) where can I get a vacuum diagram to know where vacuum should go (I think there is a port in the top of the canister, then also a port coming off of a check valve that is on top of the canister and (2) other than the tank not venting, could this cause other issues for me in terms of running or driveability?
Engine: 4++,350 & 305 CIs
Engine: Lb9
Transmission: M20
Car: 1985 IROC-Z
Engine: 383
I was just looking at this, what is the "CCV Air in"? I have a vented cap in that valve cover, is that sufficient or should it be something else? It is not hooked up to a vacuum line.
Also, I don't have an EGR so I can I just cap that vacuum line at the tee?
Car: 89 Iroc-z
Transmission: TH400
You can use a vented breather for air in i beleive. I did that in my hsr 383 with no issues
Car: 1985 IROC-Z
Engine: 383
I hooked up my vacuum lines per the diagram (except for the EGR, which I don't have). I just stopped for gas, when I turned the cap, so much air game gushing out that it literally blew the cap out of my hand. Not sure what to try next, or just leave it?
Andrew Prakash
Sep 8, 2015 11:48 AM
