Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
superram intake manifold
Old Feb 8, 2015 | 07:01 PM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
I was mocking and test fitting my supperram intake manifold and it wouldn't clear my 113 vette heads i noticed it had more material on the intake bolts thus not being able to clear is it ok if i grind them down a bit on the outside to make it flush like the oem intake manifold
Old Feb 8, 2015 | 07:36 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: superram intake manifold
You'll be fine, just be sure to use a strong washer with each bolt that will cover the larger diameter of each bolt hole your increasing in size, just in case the bolts themselves that your using have smaller heads on them than what will now be needed. Unless you mean the sides of the intake are hitting the valve cover, then yes, just grind them down.
Old Feb 8, 2015 | 08:56 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
How about the accel superman on eBay for $3600.lmfao
DiabloWS6's Avatar
Thanks for the help yes i meant the side of the manifold. I will slightly grind them down just enough for it to make a nice contact with the block/heads
Old Feb 8, 2015 | 09:04 PM
DiabloWS6's Avatar
3,600 is that right?
Old Feb 8, 2015 | 09:10 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Its probably the complete stand alone setup that was ment to be put on a old non EFI car/truck.
Old Feb 8, 2015 | 09:14 PM
DiabloWS6's Avatar
Oh i see u was like wtf
Old Feb 15, 2015 | 07:41 PM
DiabloWS6's Avatar
I noticed that the intake manifold has another water passage on the passenger side front of the manifold the oem does not have it can i just plug it up
Old Feb 15, 2015 | 08:39 PM
TTOP350's Avatar
Its for a few different applications and yrs so it will have some things not used.
Old Feb 15, 2015 | 10:46 PM
DiabloWS6's Avatar
That's great info i was looking at pics to get a reference but could not come up with anything thaks TTOP350 for the info
Old Feb 17, 2015 | 06:41 PM
PAFORM350's Avatar
Engine: 5.7 L98
pretty sure he's got the DFI spate. Either way I'm sure he will have it awhile at that price. Ridiculous
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
