Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Hawks custom mini ram
Old Apr 6, 2018 | 02:19 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Odd looking mini ram
https://m.ebay.com/itm/85-92-Camaro-...kAAOSw52Zax8IR
Old Apr 6, 2018 | 02:37 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Hawks custom mini ram
Odd.. Na looks like sh&^t. Probably flows great though
Old Apr 6, 2018 | 02:41 PM
Engine: Lb9
Transmission: M20
Looks similar to the hsr, with corvette tpi fuel rails.
Old Apr 6, 2018 | 04:22 PM
ULTM8Z's Avatar
Yeah, that's not a Miniram. The runners are too long. I agree with Tuned, it looks like a modified HSR.
They're covering all their bases in the title though... lol...
"85-92 Camaro Firebird TPI CUSTOM Intake Mini Ram Stealth Ram Edlebrock"
Except the center bolts won't fit on 87-92 iron head Camaros though without elongating the holes.
Injector boses are bonded on... looks like some sort of prototype for a HSR or something...
Old Apr 7, 2018 | 12:33 AM
charlie6178's Avatar
Car: 1992 Z28 1LE
Axle/Gears: SLP dana 44 3.92
The base of that thing is the same edelbrock tunnel ram callawat used to build the +100 intakes with.
Old Apr 7, 2018 | 06:39 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Looks like something some kid made in shop class.
Do they still have shop classes?
Old Apr 7, 2018 | 01:20 PM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Welds look like dog crap, which isn't really fair to the dogs of the world.
Callaway 100+ was pure art compared to that pos.
Old Apr 7, 2018 | 02:18 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
That's quite a Frankenstein. Looks like a tunnel ram intake with a lid welded on the plenum to make it forward facing. JB welding the injectors bungs instead of welding. Is there really not an off-the-shelf thermostat housing that required a welded one?
Old Apr 7, 2018 | 06:28 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
lol didn't see the JB welded injector bungs till you pointed it out, piece of junk.
Old Apr 7, 2018 | 07:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
I see lots of rubber hose and worm gear clamps, quality work there
Old Apr 7, 2018 | 09:51 PM
Abubaca's Avatar
I don't think this is a Hawk's intake in that they made it. ...I think it's something on the shelf, might as well sell it on Ebay type of thing. If we know anything about Hawk's.....(and I'm a customer/supporter of theirs)....they ain't cheap. If they were really proud of this thing, the price would reflect it for sure!
Old Apr 8, 2018 | 02:17 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
looks like they ran out of money....and finished with JB weld...from the looks of the fuel reg..they might have used a Stock TB. (to small)..with some clean up and polish might work...
Old Apr 8, 2018 | 03:03 AM
Twin_Turbo's Avatar
Must be me but I think it has potential.
Old Apr 8, 2018 | 12:38 PM
Car: 1992 Z28 1LE
Regardless of how it looks, and the finish work, there's no arguing it would work just well as the rest of the tunnel rams on the market
Old Apr 8, 2018 | 12:39 PM
better fittings.. fuel lines..and more time taken to set up the outside.. finish the welding..i don't see why not...its a good start..just needs a better finish/completion
theTPIS mini ram is way over priced for what it is ($800)..lol we all know that..
and if ya have any skill..ya can make one your self..ballpark anyway..the one I did I made to top plate removable..and left out the bungs for a fitech set up..but can make any top and add bungs at anytime...just want to see how things work on a big BBC.
aluminum is easy to work with...
Old Apr 8, 2018 | 12:49 PM
Engine: Lb9
Transmission: M20
I wonder how the plenum gets affixed to the base. Bolted Under neath at each end perhaps.
Old Apr 8, 2018 | 06:31 PM
ya you can see one of the bolts in the photos..I did mine way short..7" from top to bottom of intake... I wanted it to clear the hood...
the one listed needs a better fuel reg.. and better fuel lines..just more work.
CaliBranden
Southern California Area
62
Apr 11, 2012 12:58 AM
88IROC5.7
Nov 10, 2007 07:29 AM
jdaniel
May 9, 2003 08:06 PM
