neons???? help
Old Jul 6, 2002 | 10:19 PM
redbird6815's Avatar
neons???? help
im thinking about putting some neons on my red 91 bird and wanted some color suggestions I pretty good with the whole electronic thing and wanted some suggestions on mounting details and such. im tired of those hondas runnin around i know im not the only young kid in hear that has some sense i just turned 16 and would trade my bird for anything!!!
Old Jul 6, 2002 | 10:30 PM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
are you talking about undercarriage lights?? i did a set about 3 weeks ago in red(my car is red/black) it wasnt that hard but it was very time consuming..post back if you need help and ill try and guide you through it..like i said it isnt that hard at all just time consuming
iroc2nv
Old Jul 6, 2002 | 10:34 PM
89RagTopRS's Avatar
Car: 89 Camaro RS Convertible
Transmission: NWC T-5
I don't think neons would look good on that car simply because it is red. There really isn't a colored neon that goes well with it IMO. If it were white, then you'd be able to use any color.
As far as mounting is concerned, it depends on the kit where they are mounted. Most are mounted on toward the gfx where subframe connectors are mounted. However, if you have SFCs, you could probably mount them there.
No offence, but you wrote a lot of non-sensical garble here. Please check what you write before you hit the post button. I'm kinda having trouble understanding what you were saying other than neons and where they mount.
Old Jul 7, 2002 | 06:59 AM
sorry about that by the way that "would" should be a "wouldn't" anyway i just want some tips on making them look better cause ive seen a few with the tubes hanging down and it doesnt look good at all. thanx
Old Jul 7, 2002 | 08:45 AM
iroc2nv's Avatar
Axle/Gears: 3.45
before you permanently mount them check with someone and see if they can see the tubes..if you are alone(which you shouldnt) jump out from under the car...where i put my sides are directly behind my side skirts(i have an iroc though not sure if yours will be the same) and you cant see the bulbs..the front and the back are mounted on the brackets where the rebars used to be(took them out for customization...another story)..
they look good if done properly..ive gotten soo many replies on them that i think they do well on any car not just 3rd gens
iroc2nv
Old Jul 8, 2002 | 03:16 PM
nndestiny's Avatar
neons
i put green neons on my 92 TA and you can't see the bulbs at all so it can be done to our bodystyle!!!! do you get a summit catalog?? that is where i ordered my neons(they are streetglow)and they went for about $180 or so.post pics up when you get your lights on
-nikki-
Old Jul 8, 2002 | 03:23 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
You would trade you car for anything? I got a hotwheel... Or did you mean to says you wouldnt?
Old Jul 8, 2002 | 05:38 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
We recently installed 2 Street glow Blueline kits and them some. The car is red and the kits are red.
We mock installed everything with just the one kit. With the car as low as it is the kit looked bad. The light seemed too patchy. The short tube was too short for the front. I wanted it to be a nice glow all over under the car. I wanted there to be no unlit sections. I also did not want the tubes the be visible. It ended up that the short tubes that are designed for the front were just the right length for the side s if you placed 2 of them on each side. So we got another kit. I used the long tubes in the front and back. 2 long tubes are up front, on each side of the airdam. I have one long tube in the rear. I mounted it in a channel that is right where the rear bumper ends under the car. The last long tube got mounted on the torque arm. The short tubes fit in nicely between the subframes and the pinch weld.
Then we checked the lighting and found some blank spaces. My centered exhaust covered up a huge amount of the neon. So off to Discount. They just started to carry neons. I got a Street glow 20 in tube. This mounted on the gas tank heat shield b/w my exhaust pipes before the tips. Then we mounted 2 15in tubes to the rear axle tubes. Then for a finishing touch, a 12in slim tube was mounted to the front side of the crossmember. Now the only blank spot is at the transmission crossmember. We will probably tackle this in the next week or so. I am getting some pics developed from the last show I was at. Hopefully I will have them online by the end of the week.
Old Jul 8, 2002 | 05:56 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
Hey man..get a street glow gold kit from here: Car discount stereos. For red, try not to go w/green or blue..i personally think orange or purple..i put turquoise under my green camaro..loox good..cant see any bulbs..if u need help installin gimme a holla..KCobain147@aol.com..ill give ya some tips..ill be able to show u pix of my install by the end of the week..im takin some pix tonite and prolly developing them tomorrow
Old Jul 8, 2002 | 09:53 PM
Special K's Avatar
"would trade my bird for anything!!!"
OK.. this confused me for a long time. I must have read it over three times untill I figured out it was a mistake.
Old Jul 9, 2002 | 09:12 PM
i put the neons on today thanx for te help guys and that "would" is supposed to be a "wouldn't" i love my bird
slickrock55
Dec 3, 2001 10:48 PM
86bird_28v6_5spd_ramair
Nov 12, 2001 08:33 AM
Nov 4, 2001 01:01 AM
vortech305
Oct 20, 2001 05:42 PM
Jim 86 Bird
Jul 12, 2001 11:55 PM
