How do you get the rubber off the quarter panel after going to the track?
Old Aug 25, 2002 | 05:09 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
The rubber is really stuck on the paint. Washing just kind of smears it. I have used WD-40 before but it takes the wax with it. I have put wax on the quarter before racing and it helped a little.
Old Aug 25, 2002 | 05:18 PM
350tbi's Avatar
spray baby oil on the quaters before you race it will come off easy then.
Old Aug 25, 2002 | 05:21 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Hey thanks. I never thought of that.
Old Aug 25, 2002 | 11:57 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
You can also smear vaseline real thin over the lower quarters.
Old Aug 26, 2002 | 12:06 AM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
Meguires
Meguires (sp?) quick detailer before (at the track) and after to help get it off, sorta the same concept as the baby oil, but in a car car product
Old Aug 26, 2002 | 12:32 AM
JAY4SPEED's Avatar
Take paste wax and put a very heavy coat on the rear quarters before you goto the track. Rubber comes off of wax easier than paint.
Old Aug 26, 2002 | 09:01 AM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
Did you try to use a Bug N Tar remover? You can find them pretty easily at almost any parts store.
Z
Old Aug 26, 2002 | 03:53 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I have tried the thick wax but it still wanted to stick on. Definitely better than nothing at all. I have some rubber that I need to get off so I think I'll do like Kzad said and get some tar remover. Then I'll use the baby oil or vaseline. Thanks guys. That helps.
Old Aug 26, 2002 | 04:34 PM
formul8!!'s Avatar
Car: 2004 GTO
I go to the jet-wash and pick the bay with the highest pressure, if possible.
The really high pressure usually blows it right off.
Works great in the wheel wells too!
Old Aug 26, 2002 | 06:52 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I did happen to go to the car wash and even put the presoak on it and let it sit for a minute and high pressured it for a while. Some came off but most stayed. Those M/t's really have some sticky rubber.
Old Aug 26, 2002 | 07:43 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Gas, laquer thinner, mineral spirits. Any of those will work fine.
If it's really stubborn then use one of those plastic scrub sponges they sell for pots and pans. Not an S.O.S. pad, they're a sponge with a plastic "net" around them.
Of course you'll have to re-wax that area, but don't worry, it won't hurt the paint. A buddy of mine works at a detail shop and they use mineral spirits to get bugs off cars all the time.
AJ
morrow
Jan 13, 2024 12:29 PM
gta892000
Aug 11, 2019 11:16 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
katrav8
Sep 11, 2015 09:00 AM
84 TA NV
Sep 6, 2015 08:02 PM
