S-10 Xtreme Rims, what lip do I need to grind to get them to fit?
Old Aug 26, 2002 | 03:33 PM
zer0321's Avatar
Got my 16x8" S-10 Xtreme Rims in the mail....now I want to put them on my car (to go with my new paint!), but everyone says there is a lip I need to grind off in order for them to fit properly....can someone describe/show me where this lip is, and what the best way to grind it off is?
Old Aug 26, 2002 | 09:23 PM
zer0321's Avatar
...anyone?
Old Aug 27, 2002 | 12:27 AM
zer0321's Avatar
I know someone has the answer...
Old Aug 27, 2002 | 12:46 AM
NEEDforSPEED's Avatar
whate abit the answer well come,grasshoper
Old Aug 27, 2002 | 02:30 AM
zer0321's Avatar
I hope so.
Old Aug 27, 2002 | 02:56 AM
jawzforlife1's Avatar
might want to try a search for the wheels, and when you find a pic, PM them. people with the wheels might not see this post, so you might have to track them down.
Old Aug 28, 2002 | 04:15 AM
zer0321's Avatar
well, I can only think of one other person on here that has them, and I tried sending them two e-mails (as they don't accept PMs)...
so what now?
Old Aug 28, 2002 | 06:12 AM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
If you call Miss Cleo I bet she could tell you. She knows everything.
:hail:IROC-Z
Old Aug 28, 2002 | 12:26 PM
FLYNLOW92rs's Avatar
Contact a member named.......
Xtreme92 or something
he has them on his car.....
Old Aug 29, 2002 | 07:39 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Well, the bolt pattern is the same, but I am sure the backspacing is not. Try and bolt one on the car and that should give you a rought estimate of the back spacing you need.
Old Aug 29, 2002 | 10:20 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I vaguely recall someone saying they had these wheels.
IIRC, they had to grind down the lip on the Control Arms up front because of the way the wheel is designed, and due to the backspacing.
The only other thing I can think of where a lip may be is on the inside of the center hub. Maybe that steel shim that's on the rear of our cars (for the stock 16" wheels anyway) has trouble sitting against the hob of the Extreme wheels because of some lip on them?
If you haven't already, try posting this on the Suspension board. You may get a few more responses there.
AJ
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Street Lethal
Apr 30, 2019 12:14 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
kah992
Aug 19, 2015 02:55 PM
TreDeClaw
Aug 14, 2015 06:58 PM
