Help guys
Old Sep 8, 2002 | 02:06 AM
Spider7's Avatar
Help guys
Ok, I am looking at some rims, but.... what size back spacing do I need? Is it 5"??? These wheels are only 3.25.... that won't work right?
Old Sep 8, 2002 | 03:12 PM
devianb's Avatar
We can't tell you the backspacing you need unless you give us the width of your rims. For 8" rim, you would need 4.5 inch backspacing. Thats the only backspacing dimensions I know of.
Old Sep 8, 2002 | 10:51 PM
Spider7's Avatar
Ok, so a 15x8 with 4.5 bs and no offset will work???
Old Sep 9, 2002 | 07:03 AM
Spider7's Avatar
Anyone?
Old Sep 10, 2002 | 12:27 PM
devianb's Avatar
15 X 8 width 0 offset and 4.5" backspacing should work. I have All 0 offset GTA wheels on my car and it works out perfectly. I don't know if your TA has the 16mm offset rear disc setup. If your TA came with the 15 x 7s , you should use 0 offset or 4.5 inch backspacing all around for an 8 inch wide rim.
Hope that helps
Old Sep 10, 2002 | 02:03 PM
Spider7's Avatar
I don't have rear disc brakes at all, so I should be set then huh?
Old Sep 10, 2002 | 05:31 PM
devianb's Avatar
You should have no problem. I didn't with 0offset GTA wheels (16 X 8) on all four corners.
Old Sep 10, 2002 | 10:55 PM
Spider7's Avatar
Sweet, thanx for all your help man
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
