17x8 what backspacing tire size?
Old Nov 30, 2002 | 08:27 PM
scrawnywhiteguy's Avatar
Ok, I've been thinking about different rims and I was thinking about the weld racing pro starXPs in 17x8, what backspacing will I need with 17x8s and what tire size. I want the tires to be as close to stock diameter as possible. Thanks in advance.
Tim:rockon:
p.s. if you have 17x8s (any rims) please post pics, rim type, and tire sizes. Thanks again.
Old Nov 30, 2002 | 08:30 PM
here's a pic I found of a thirdgen with these rims.
Old Nov 30, 2002 | 08:40 PM
caspergotaz28's Avatar
Car: 1992 Camaro Z28
As for tire size, you will want to go with either a 245/45/17 or a 255/45/17.
Your stock size tire (245/50/16) has an overall diameter of 25.6"
The 245/45/17 has an O.D. of 25.7"
The 255/45/17 has an O.D. of 26.0"
Probably the 245/45/17 is the way to go to keep the same O.D.
As for offset I think it is 0mm for the front; and positive 16mm in the rear. I am 90% sure those are good numbers for an 8" wide rim.
Old Dec 1, 2002 | 06:29 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
My wheels (see sig pic) are 17x8 Centerlines with 4.5" backspacing. The tires fit to the outside of the wheelwells, but under the fender lips. The tires are Bridgestone Potenza SO-2's in size 255/40/ZR17. They are only 24-1/2" tall. I would suggest going with a taller tire as my tires don't fill the wheelwells like I really wanted. BTW, different manufacturers' tires will have different measurements, i.e. a Goodyear 255/40/ZR17 might be 25" tall instead of 24-1/2", etc. Good luck.
Old Dec 1, 2002 | 06:32 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
4.35" front and 5" rear backspacing will make them fit identical to stock. But my car also has 4.5" front and rear and it fits fine, and gives the back an aggressive look
Old Dec 2, 2002 | 03:43 PM
That's actually about the way I like 'em to fit. Thanks for the info.
Tim:rockon:
Old Dec 2, 2002 | 11:34 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
would backspacing be the same on a 17x9in wheel?
like these eagles
model 212
model 220
Old Dec 3, 2002 | 02:03 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
http://gs.tolan-hoechst.com/tirecalc.htm
This will tell you the diameter, change from stock.... etc.
AJ
Old Dec 3, 2002 | 07:51 AM
sbrice18fan's Avatar
Car: 1990 Chevrolet Camaro RS
My 17X9 rear wheels have 5 1/2" back spacing.
Old Dec 3, 2002 | 07:24 PM
Car: 86 Z28
Axle/Gears: TBD
do you have pictures of your wheels on your car?
Old Dec 5, 2002 | 11:47 AM
check out my website in my signature.
Old Dec 5, 2002 | 02:59 PM
Car: 86 Z28
Axle/Gears: TBD
will 5in of backspacing work all round or will the 5.5 work all round i want to keep wheels all the same
if i get 5in backspacing will they rub anywhere?
Old Dec 10, 2002 | 11:17 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
5" is the absolute max you can run up front, and 5.85" is the max in the rear.
http://www.skulte.com/adapterfaq.html
Old Dec 10, 2002 | 07:12 PM
TheWraith's Avatar
Engine: 355
for the record, that can vary by car. I was with a friend of mine when he got new tires put on his 87 formula with it's stock 16" wheels. One of the rear wheels, which has 5" backspacing, was put on the front of the car accidentally, and made a horrible scraping/rubbing noise backing out of the garage. It did NOT clear everything properly. another 1/10 of an inch might have done the job, but 5" backspacing did not.
Old Dec 10, 2002 | 08:47 PM
Car: 86 Z28
Axle/Gears: TBD
4.5 all the way around it is then
Old Dec 11, 2002 | 06:32 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Wraith,
Thanks for letting me know. I used to have 4.85" listed, but some folks were running 5" w/o problems, so I changed it. Did the rubbing happen on the lower ball joint or a tie-rod end? I've seen some aftermarket (non-GM) replacement parts that would rub, while the GM stuff didn't. If you could find out, that would be a huge help. I'd love to add that detail to the wheel spacing FAQ which should help a few folks out. Thanks!
Andris
Old Dec 11, 2002 | 03:11 PM
TheWraith's Avatar
Engine: 355
Wraith,
Andris
andris, i wish i could tell you, but this was over 6 years ago, and that car is long gone, so i can't reproduce it.
This is an exact clone of the car though. 87 LG4/auto formula, rear drums, with those 16" wheels.
Maybe those wheels specifically came with a slightly different backspacing even?
Old Dec 19, 2002 | 05:13 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
I know this is a backspacing topic but you can figure out how to stay close to stock diameter by this: For example 275/40/17 Tire diameter computes as follows. divide 275 by 25.4 (this will give you inches across the tread) which in this case is 10.8. Then take 10.8 and multiply it by the series size. In this case again that would be .40 (for 40 series tires). The outcome is 4.32. This is the size in inches of one sidewall. Now you have two sidewalls in figuring tire diameter so multiply your answer by 2 and add 17 for the rim size and you have your tire diameter. The tire diameter for 275/40/17 is 25.64 inches. Wala.
Old Dec 19, 2002 | 04:10 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
That will happen with nearly every car with stock rims. However, increasing rim size to 17-inch will aleviate the clearance issue and allow for larger backspacing. You have to pay attention to what is rubbing and how that can change with rim diameter.
17x9 with 5-inch backspacing fits all the way around. I have it on my car. 17x9.5 with 5.5-inch backspacing fits all the way around and sits in the same position on the outside of the car. The extra width is placed inward. Your turning radius from lock-to-lock will likely be reduced, especially if you have aftermarket sway bars. 18x10 with 6-inch backspacing will fit on the rear. Other wheel combinations can be used, too. Just be sure to measure up and double check fitment before purchase.
fasteddi
Sep 10, 2015 09:32 AM
TheTraut88
Sep 7, 2015 05:22 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
