t-top help
Old Dec 9, 2002 | 08:42 AM
transam305's Avatar
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
t-top help
hey how hard is it to replace the weather strip on the tops of our cars? i plan on doing this because right now i have major leakage and a totally ruined headliner because of this plus everytime it rains i get dripped on by my car and it get's kind of depressing after awhile. plz let me know how hard it is to obtain all i need and how much time is it going to take me to replace it all and should i do it myslef or have it done?
Old Dec 9, 2002 | 09:25 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Do a search. There are several tech articles on how to replace the T Top weatherstriping. altho my tops don't leak if they did I would be depressed but I also would do something about it right away. But then I hate anything that does not work so I repair all non working items right away. You can also find a tech article on replacing the headliner also. I would do both at the same time in order to be ready for the rainy season and the summer. Plan on spending aboyt $500.00 for both projects combined.
Old Dec 9, 2002 | 02:04 PM
transam305's Avatar
thx i didn't know that the tops leaked untill one day i left it out in the rain because i stayed over somewhere where i couldn't park it in a garage and my center counsel was full of water and the passenger side floor was nothing but a puddle. do you know the links to the tech pages?
Old Dec 9, 2002 | 02:18 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
i did it and it wasnt too hard at all......just need a second person to hold the silicon gun and to hold the stripping in place......i bought mine off www.yearone.com ......i know that 500 is way too much......200 max i think......took me like a week to do it
Old Dec 10, 2002 | 02:29 AM
F0xBody50's Avatar
Mine leak very little.. but it still annoys me...
I'll need to replace mine at somepoint, but for now I've seen weather-stripping for sale @ Hawk's ThirdGen Parts.
-LJ
Old Dec 10, 2002 | 07:45 AM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
are you sure it's the seals? mine leak, but it's not the seals fault.. the sealant material that held the seals was no good, thus the water was going under/past the seals. I'm nailed 90% of the leaks. which wasn't to bad for my first attempt at re-sealing them.
Old Dec 10, 2002 | 07:56 AM
tigersZ's Avatar
If you have a puddle in the floor of the passenger side I don't know if that is caused by the t-tops leaking. I would check the seal around the windsheild. I have had this problem in a Caveliar and that was the probelm. I would check that. It could also be the tops. I know I have to replace mine. Anyone want to come over and do it for me because I don't think I have the patience to do it my self.
Old Dec 10, 2002 | 08:19 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
I also have this problem. My leaks swap spots every so often. Everytime I do a power slide around a corner and the damn chassis tweaks just alittle, the leak moves. It sounds dumb, but it does. Most of the time, i just get a small puddle in the pass seat. But lately, ive noticed that its leaking in the center, and running alound the roof sheet metal and down on the back seats. When I do mine, Im gonna do EVERYTHING. Im gonna take the old crap off, get rid of any rust, re-seal the t-bar, and put new seals on. The previous owner tried to fix the seals with silicone, but did a really crappy job. Anyway, have fun. Those seals are expensive, but worth it if it stops you from gettin wet. Let us know how it turns out.
justin
Old Dec 10, 2002 | 08:22 AM
transam305's Avatar
well what happends with the puddle on the floor is it leaks on the passanger side twords the back and then kind of runs down into the floor from there because the back is all wet to usually. but thank you all for the respones if anyone else has any ideas let me know i'm always open for advice.
Old Dec 10, 2002 | 08:29 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
If theres a puddle on the passenger side floor, check the door for leaks. Mine used to leak a little and I'd see a couple drips on the door panel. The weatherstripping had come loose, so I just reglued it down.
Old Dec 10, 2002 | 08:34 AM
transam305's Avatar
so along with the seals around the t-bar i should check the seals on the t-tops themselves along the door/window?
Old Dec 10, 2002 | 10:15 AM
MdFormula350's Avatar
https://www.thirdgen.org/newdesign/t...pleakfix.shtml
https://www.thirdgen.org/newdesign/tech/ttops.shtml
Old Dec 11, 2002 | 08:20 AM
transam305's Avatar
thx for all the suggestions guys it really helps me out a lot.
Old Dec 11, 2002 | 09:12 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
i have a problem with leaking but it isnt the t-tops.. sorta.
my leaks come from the window seal area. how can i fix it rather then replace it.. i figured it was a gap where the t-top weather seal and the door seals meet.
Old Dec 12, 2002 | 08:24 AM
transam305's Avatar
i'm guessin you can try and reglue or patch up the gap in the t-top seal around the window is that where it's leaking?
Old Dec 12, 2002 | 03:42 PM
HamSpiced's Avatar
well i never take my t-tops off or do i ever plan to, so im proabably going to just glue the two separate weatherstrips together permanantly.
Old Dec 13, 2002 | 08:22 AM
transam305's Avatar
why don't you take your tops off? if you don't take them off just seal the crap out of them or something i don't know i just don't understand why you don't drive around with your tops off? it's great!
Old Dec 13, 2002 | 08:43 AM
HamSpiced's Avatar
cause i hate t-tops. no offence, but whats the point of having half a convertable. i wanted plastic ones cause at least those are lighter. but i think ill keep my glass ones, they are in prefect condition.
Old Dec 13, 2002 | 11:18 AM
transam305's Avatar
that's tru but i just think t-tops are nice unless they leak but i do agree i'd rather have a hard top only because i know that it won't leak!
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
