Biggest Tires For Rear????
Old Feb 1, 2003 | 02:23 PM
GokuIrocZ's Avatar
I've just bought New Iroc 17's and am Wondering The Biggest Tire I could put on the Rear....I was going togo with 275/40/r17 BF Goodrich Comp TA's for the rea, and 245/40/r17 in the front, will the 275's fit???
Old Feb 1, 2003 | 03:54 PM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
i had that exact size (except 16 inch) on my iroc rims in the back and they fit perfect...the look from behind the car was amazing..
post pics man
iroc2nv
Old Feb 1, 2003 | 05:23 PM
devianb's Avatar
What width are your rims.
Old Feb 1, 2003 | 05:31 PM
iroc2nv's Avatar
Axle/Gears: 3.45
as long as they are 8 inch..they can take the 275..ive heard they can even take the 295..but i think thats pushing it
iroc2nv
Old Feb 1, 2003 | 05:57 PM
Kandied91z's Avatar
275/35 front
295/35 rear....don't think i would go 295/40 though as it's tight!
the look is amazing....
Old Feb 1, 2003 | 06:07 PM
ThirdGenZ28 92's Avatar
Car: 1992 Z28
Engine: Stock L98 with bolt ons.
Transmission: Stock rebuilt tranny with 2k stall and cooler.
Im running 275/40/17s all around and the fronts do rub a bit at full lock in either direction of the steering wheel. The rear isnt exactly centered as large bumps bring the rear pass side wheel lip down slicing my rear tire, I think if I center it better itll fit no problem or roll the wheel well lip to help keep the tires safe...
Old Feb 1, 2003 | 06:32 PM
devianb's Avatar
Originally posted by Kandied91z
275/35 front
That would be a lot of tire for an 8 inch rim. I must be looking at too many imports because I think 245s on an 8 inch rim are already big enough. I wouldn't go any larger than 275.
Old Feb 1, 2003 | 07:57 PM
Kandied91z's Avatar
i thought the question is what size tire can you fit.........not what size rim.
obviously if a 8 is stock an 8 will fit. i wouldn't go any larger than a 255 and then i'd stick with a 45 or smaller profile to keep the stock 245/50 look.
anyone who puts a 275 or even a 295 on a 8" rim is a little off their rocker.:lala:
Old Feb 1, 2003 | 08:13 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
how exactly do you measure a tire? like what is 275?
Old Feb 1, 2003 | 08:34 PM
Kandied91z's Avatar
275 is width
35 is the percent of the width applied to the sidewall
18 would be the size of the rim
h,r,z,w,y are all ratings for speed....
mine are 275/35/y18 which is good for 180+
the rears are 295/35/y18 which is also good for the 180+ range
Old Feb 2, 2003 | 09:26 AM
GokuIrocZ's Avatar
Well I think the 17 Iroc's are 17*8, and the tire sizes are 275/40/r17, you guys don't think it would look right??? hum
Old Feb 2, 2003 | 09:48 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
post pics man
iroc2nv
what tires did you buy to get 275/45-16s ?
Old Feb 2, 2003 | 02:39 PM
iroc2nv's Avatar
Axle/Gears: 3.45
they were bfg comp t/a's...i sold them to iroc_canuck..i know they are discontinued now so i dont think you can get them unless you find someone that has them in stock
iroc2nv
Old Feb 2, 2003 | 02:44 PM
iroc2nv
do you know when they got discontinued so that i would have an idea if anybody would have some?
Old Feb 2, 2003 | 04:07 PM
iroc2nv's Avatar
Axle/Gears: 3.45
ill call my supplier tomorrow and find out...
iroc2nv
Old Feb 2, 2003 | 07:41 PM
Thanks a lot!
Brady
Old Feb 3, 2003 | 06:20 PM
iroc2nv's Avatar
Axle/Gears: 3.45
ok..
i got the skinny..
this is what i had on my iroc...
295/50/16 bf goodrich comp t/a's product # 51487
i hope this helps..
iroc2nv
Old Feb 3, 2003 | 06:35 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
How's this?
Old Feb 3, 2003 | 07:56 PM
Car: 1984 Z28
is that legal?! or even possible!?
Old Feb 3, 2003 | 08:29 PM
ok..
i got the skinny..
i hope this helps..
iroc2nv
thanks,
brady
Old Feb 3, 2003 | 08:47 PM
iroc2nv
a 295 WILL fit on a 8" wide rim. but it wont look as good or perform as good as the same tire on a 10" rim
i think its illegal
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
z28addict8490
Aug 7, 2015 08:48 PM
