How do I get this out?
Old Feb 22, 2003 | 10:36 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I didnt know where to post..
I wanna take this out and replace it or aleast clean it up....but I cant figure out how to get it off the car...anyone know?
Its the rubber bumper stop that you can adjust for the hieght of the hood once closed...
Old Feb 22, 2003 | 10:46 PM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
I think you just unscrew it out. should be counter-clockwise.
Old Feb 22, 2003 | 10:49 PM
I was going to try that but i was scared that the bottom end or something would fall out or thru...and you can reach up under it..
For some reason it doesnt feel like it unscrews to the get off...
Are you sure? have you taken your off?
Old Feb 22, 2003 | 10:51 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Over time, those will rip, making it seem as though they won't unscrew, just work at it a little, maybe with a little help from a small screwdriver, it will come out. Make sure you have replacements first though.
Old Feb 22, 2003 | 10:56 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
I don't know if this will help you, but...
Old Feb 22, 2003 | 10:57 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Second...
Old Feb 22, 2003 | 10:58 PM
they unscrew but are you sure theres not a bottom piece that will fall out? I can turn it to adjust it jut fine...I just want to take it off to replace it...anyone know the part #?
and I just want to make sure that I can put it back on...I wouldnt think GM would make it where a piece would fall off and then we wouldnt be able to get to the other end...
you know how GM is though
Old Feb 22, 2003 | 10:59 PM
good deal...so they do just unscrew out......thx a bunch man!!!
you got a part number?
Old Feb 22, 2003 | 11:09 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
I don't have a part # for you, but your local GM dealership will be able to get that with no trouble. Classic Industries sells them also, as with many other restoration companies.... CI number is
G9878 for 82-84 and G6262 for 82-92 , no idea as to why they list differant #'s... I would suggest going to GM.
Old Feb 22, 2003 | 11:21 PM
MikeS's Avatar
It seems like a standard enough item that you may be able to find it on the shelf at a parts store with all the generic "help" stuff.
Old Feb 23, 2003 | 10:45 AM
Vader's Avatar
It is. Two per package for a few bucks. Motormite/Dorman P/N 45392.
