91-92 camaro gfx on firebird?
Old Feb 28, 2003 | 07:21 PM
91fbirdgta's Avatar
Car: 91 Firebird GTA
i think i saw it before with zepher (spelling?!); just to be sure, my question is can it be done? can the gfx from a 91-92 camaro fit onto a 91 gta? JUST THE SIDE SKIRTS-I've been thinking about this for quite some time now, and wanted to know if its possible, and if so, how it looks!
the pic below is of the side skirts I'm talking about-will they fit!?!?!
thanks for any info-
Old Feb 28, 2003 | 07:58 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Oh yes they'll fit. Though you may need to put some kind of filler or fiber glass or make a stud to go behing the emblem so the front part of the rocker gfx will bolt to the fender, or have a emblem made to cover up the hole for it and use the original two screw method into the fender. Try pm'im Zepher and see what he did.
Old Feb 28, 2003 | 08:28 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The rocker panel bolts right on, the door pieces need new holes drilled as well as the old holes filled.
There are 6 holes on each side to fill after you do this swap, unless your bird is an 84 which has the lower ground effects, then no holes will need to be filled since the 84 T/A uses the same holes as the 91-92 Camaro rocker and door pieces.
Old Mar 1, 2003 | 01:58 AM
devianb's Avatar
I think it looks great
Old Mar 1, 2003 | 07:25 AM
theSteve's Avatar
Car: 1985 Trans Am
Engine: upgrading...
Transmission: upgrading...
agreed.
now this is definitely one of my upcoming projects.
Old Mar 1, 2003 | 07:53 AM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Won't those look funny on a 91 GTA, since it has the... let's just say "unique" 91-92 Firebird style ground effects? What are you planning to do with the front and rear sections? The front probably won't look bad, but mixing the somewhat-flat Camaro side pieces with the upswept 91 rear effects & bumper cover is going to look mismatched. You'd probably have to swap on a 85-90 T/A rear cover & rear f/x to make it look right.
Old Mar 1, 2003 | 10:51 AM
91fbirdgta's Avatar
thanks guys, yep thought you had that done zepher! looks sharp! so let me see if i'm understanding u right, the panels under the door don't need new holes-they'll just slip onto my car? and the door panels need new holes and the old ones filled, gotcha. let me ask you, what did u use to fill the the old holes, cause I'm thinking of doing this project, and some other ideas in the spring/summer time, then have the car painted (cheaper that way ) and thanks 4 the info!
Firebird 383, yep thats what I was planing to do-use the gfx from around that year to put on the back- the pic's back bumper is what i had planned-
another question, zepher, you mentioned that an 84 ta has lower gfx, u have a pic of them?
Old Mar 1, 2003 | 10:55 AM
91fbirdgta's Avatar
don't know whose car that is, but i photoshoped the gfx to match the color of the car
I like those dropped cars
Old Mar 1, 2003 | 04:32 PM
Zepher's Avatar
If you look at the two images that I posted of the body work being done, take note of the black paint where the fender vent is, there are two holes in the fender for the rocker panel. The 84 T/A and the Camaro's rocker panels are the same height in teh front and rear, whereas the 85-90 T/A are about 2 inches taller.
Oh, and Bondo was used to fill in the holes in the door. I still need to have the 2 in each fender and one in each of the rear quarter panels filled.
Old Mar 1, 2003 | 07:52 PM
theSteve's Avatar
Car: 1985 Trans Am
Zeph, what did you put in the emblem spot? i can see theres something in there -- i think -- but i cant tell what it is.
it looks pretty shallow actually... you think it'd be pretty easy to fill in?
Old Mar 1, 2003 | 11:39 PM
Zepher's Avatar
I made a WS6 emblem that was supposed to be red but turned out pinkish.
There is masking tape residue over the top of it, that is why it looks all scratched.
Old Mar 2, 2003 | 12:10 AM
devianb's Avatar
91fbirdgta,
The 91-92 Camaro Ground effects indeed will look kind of wierd on your 91. You won't have the same holes to fill as Zepher did because the 85-90 TAs bolt up differently than the 91-92 sides.
Zepher,
Thanks for the info on mounting the sides. I am thinking about adding 85-90 Camaro sides, but without the door molding. I would have to modify it a bit to match the TA front I am also planning on.
Old Mar 2, 2003 | 12:52 PM
91fbirdgta's Avatar
devianb, I'm gonna take the existing side skirts off, and the back bumpers gfx and put on the one thats on the blue ta(zephers too) so tell me how its gonna look wierd-its gonna look cleaner plus the fact that not that many thirdgens have them
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
I'llrocya
Feb 2, 2016 11:43 PM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Aug 20, 2015 03:55 PM
