MSD Box install pictures
Old Mar 20, 2003 | 03:42 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Hey, i tried a search a few times and was unsuccessful. For some reason it does not accept "pictures" for me. So i looked through a lot of threads about just the boxes with little to no luck. I would just like to see where you guys have put yours. Anything creative? Inside the pass. compartment or engine bay are fine. Anything really! I am thinking of mounting it to the rear of the drivers side inner fender wall, near the master cylinder. Any other ideas. Thanks for your time-later
Old Mar 20, 2003 | 04:22 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Here's mine -
Old Mar 20, 2003 | 04:27 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
How did you do that? Is it just sitting on the vacum canister or did you fab up a bracket? Looks good, different, but still good IMO. Thanks- anyone else?
Old Mar 20, 2003 | 04:56 PM
25THRSS's Avatar
Does anyone have any pics of the MSD box mounted to the firewall?
Old Mar 20, 2003 | 07:08 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
yep...
there are a lot more on my web site in my sig. i will be adding a lot more stuff tonight, so there will be even more tomorrow.
-Brian
Old Mar 20, 2003 | 08:23 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Wow, clean motor swap Z28 Boy. Looks good. You have a few holes in the firewall, but it still looks really clean. So, how is it without wipers? I was thinking of taking the motor out since i hardley ever drive it in the rain. Anyone else with pictures of them installed? thanks
Old Mar 20, 2003 | 08:34 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I just installed mine too..haven't wired it up yet cause I'm waiting on my wiring harness...I welded some brackets in my welding class and mounted it above my battery. I'll get some pictures of it tomorrow.
Old Mar 20, 2003 | 09:37 PM
Good job man glad to hear it worked out alright.
Yeah I had a peice of steel laying around and me and my father got creative and decided to mount it there.
Old Mar 20, 2003 | 09:42 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Here is mine.... Too bad the box died on me I plan to replace it with a Crane box.
Old Mar 20, 2003 | 09:51 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Here is mine,
Old Mar 21, 2003 | 04:03 PM
Engine: 5.7
Here is my recent set-up.....just hooked it up, and it's working great
Old Mar 21, 2003 | 04:05 PM
Engine: 5.7
Another....I just got some wire loom, and covered all the wires up...looks really good
Old Mar 21, 2003 | 04:15 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Mine is in the exact same place my ECM used to occupy! Works well!
Andy.
Old Mar 21, 2003 | 10:11 PM
BOTTLEDZ28's Avatar
Transmission: A4
heres my old setup,
Old Mar 22, 2003 | 12:26 AM
maniacc's Avatar
here's one more for ya. i moved the battery toward the radiator with a bracket that was supplied with my ATI supercharger kit.
later
larry
Old Mar 22, 2003 | 08:22 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
thanks for the replies guys. Some creative ideas here. Still don't know where i should put mine. I kept the a/c so there goes one spot. I think the best way will be placing it in different spots and choosing the best spot for me. Thanks again. By the way, more pics are always welcome! later
Old May 1, 2003 | 04:58 PM
25THRSS's Avatar
any more?
Old May 1, 2003 | 06:57 PM
88GTAinRI's Avatar
From: Ocean State, lil Rhody, the biggest littlest state in the union, Rhode Island
Car: 1988 GTA Black/Gray
Engine: Blown 355
I moved the relays from the firewall to the top of wheel well, just behind the strut. Made a bracket to bolt where relays where and then bolted MSD box to bracket.
Old May 1, 2003 | 08:02 PM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
dont put it here. and then when ur distributor or starter i forget which he said goes cut the wires so that the thing is useless. learn from other's mistakes, especially previous owners.
Old May 1, 2003 | 08:03 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
What a coincidence! Just last weekend as i am finishing my swap, i removed the relays and moved them to the top of the firewall and in their place i plan on putting the MSD box. Hey 88GTAinRI, do you have the MSD 6AL with the rubber mounts, or no? I only ask b/c i am figuring out how to mount the box there with them on it! Thanks for any help and thanks for the pic. later
Old May 1, 2003 | 10:23 PM
25THRSS's Avatar
Do you have any pictures showing how you removed and relocated the relays? Thanks
Old May 1, 2003 | 10:43 PM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
here's mine
I put mine next to the evap canister.
pic:
Old May 2, 2003 | 06:03 AM
88GTAinRI's Avatar
Engine: Blown 355
I actually have the 6BTM box, same as the 6AL only it has boost retard. I cut a piece of aluminum a little bigger than the outside of the ign. box. Then I marked the holes for the box to be secured too. I drilled those holes out and secured (4) 1/4" bolts through the holes with 1/4" nuts. Then I measured the where the box would be on the fire wall and drilled two holes to mount the aluminum to the existing holes that the relays where secured too. After aliminum plate was secured to the firewall, I installed the bushings over the 1/4" studs, placed the box over the studs, and tightened the box down.
Old May 2, 2003 | 06:21 AM
ctandc's Avatar
Here's some pics of the MSD 6A mounted in the IROC I'm parting out. The MSD is sold, but I just put the custom mount on Ebay cheap, so if anybody wants it, let me know and I'll end it early. It looks clean, as shown, and it uses existing mounting holes, which made it super easy to install ( I tested the box in my IROC ).
HTH
Old May 2, 2003 | 01:17 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
i just used 3M double sided tape and ploped it on top of my battery.... is there anything wrong w/ that?
Old May 2, 2003 | 02:40 PM
I got more pictures on my webpage.
Old May 2, 2003 | 04:45 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Damn nice that I happend to find this thread by chance. Didn't search or anything. I am going to mount mine this weekend.
Occasionally fortune can smile upon me.
Old May 2, 2003 | 06:06 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Thanks for getting back to me 88GTAinRI. Sounds like a pretty good idea to me. I checked out your site and looked at one of the pictures with it in there clear as day! thanks again
Old May 3, 2003 | 10:58 AM
black84-6spdz28's Avatar
wow...i must be the only digital 6 user...
Old May 3, 2003 | 09:45 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I did the A/C Box delete and it made a HUGE space increase, ease in working on engine, and the perfect MSD spot.
Old May 4, 2003 | 10:52 AM
92camaro's Avatar
I was wondering if anyone has mounted their MSD Boxes inside the car. I am about to move mine inside on the passenger side. of the trans tunnel.
Old May 4, 2003 | 12:18 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Yeah, i have seen them on the console right next to where the passanger's knee would be. Looks tacky IMO. Sometimes things just "look better" concealed! This thing could go eitherway i would think.
Old Jun 18, 2003 | 09:53 AM
DABE's Avatar
MSD boxes themselves suck....i have had 2 of them die....everything was hooked up right...mounted right...they just took a crap...
heres a goooood suggestion for all u HEI guys....get the MSD ultimate HEI kit...comes with MSD module to bypass the box..coil..cap...rotor...coil cover...
it was the best $140 i ever spent.....its much smoother and more powerful than the damn 6al i had...
Old Jun 18, 2003 | 10:17 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Mine
Old Jun 18, 2003 | 11:58 AM
bigals87z28's Avatar
Car: Check The Sig
it sure helps not to have that AC box there huh? i think that im gunna get a small overflow bottle and bolt it to the radiator so it frees up some room and just make a braket or 3M supertape/e-z pass tape it there. Anyone using the 6AL? or is the 6A fine?
Old Jun 18, 2003 | 01:06 PM
DABE's Avatar
the only difference between the 6A and then 6AL is the AL has a rev limiter...
Old Jun 18, 2003 | 01:15 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
Old Jun 18, 2003 | 02:36 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Old Jun 18, 2003 | 04:35 PM
25THRSS's Avatar
Originally posted by TPl383
Exactly where I plan on putting mine. It would be cool to see some more pics of boxes installed on the firewall. I think it looks the cleanest that way.
Old Jun 18, 2003 | 10:06 PM
sllt1776's Avatar
Car: 89 Iroc-Z
here's mine
Old Jun 18, 2003 | 10:31 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Mine is right where the canister should be... not good if you want to pass emissions/.
Old Jun 20, 2003 | 09:50 AM
  #42
orangeroc383's Avatar
Car: 1986 IROC-Z
Engine: 383
Transmission: th350
Removed my heater box and installed the box there
Old Jun 20, 2003 | 10:39 AM
  #43
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
Here's both of mine boxes mounted on the fire wall.
Old Aug 15, 2003 | 10:46 PM
  #44
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Wow, i'm surprised nobody mounted theres wher ei have....
i found it to be pretty much the only spot... and yes it clears my hood, however, i do have a fiberglass cowl hood... i dont think its any different as far as clearence in that area tho-
Obvously, the wireing is all tucked in better, but you get the idea...
Vintageracer
Jan 10, 2020 05:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
toronto formula
Nov 10, 2015 06:17 AM
midias
Aug 15, 2015 05:07 PM
bryan623
Aug 10, 2015 11:33 AM
