Caliper and Drum paint prep?
Old Apr 7, 2003 | 09:08 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
My calipers and drums are rusty, what sould i do to prep them before i paint them?????
Old Apr 7, 2003 | 09:09 PM
joshp14's Avatar
wire wheel on a bench grinder then some brakleen to clean em. then paint away with high temp paint.
or you could have them bead or sand blasted.
Old Apr 7, 2003 | 09:21 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
What about that paint that turns rust into primer?
Old Apr 8, 2003 | 07:25 AM
Spdfrk1990's Avatar
still want to wire brush first.
Old Apr 8, 2003 | 08:41 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Please paint your drums black, or not at all.
Old Apr 8, 2003 | 04:07 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I used a wire brush and then a friend offered to blast them. They came out about the same. I then used some of the rust convertor and then painted.
Sorry fyrelance, but I painted them red all the way around...drums too! I liked it. Matched the car. though in the next few weeks I'm going to be going to a disc brake rear, so it will be a non-issue!
Old Apr 8, 2003 | 05:04 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i just put alumin drums on my 82 and i painted the drums with a nice fresh coat of alumin paint. came out nicely
Old Apr 8, 2003 | 05:20 PM
FyreLance's Avatar
Oh that's it, you just ruined your entire car by doing that. Geez what an abortion of a car, I can't believe you painted your drums. OMG OMG OMG. R<x>ice! R<x>iiiiiice!!! Save the paint drums for the mad tYte Hon-duhs!
j/k of course, just making fun of previous posts.
I don't think painted drums are too bad, especially when body color, but just not my thing really... I really like painted calipers though! All depends on the situation I suppose. It'll be sweet with four-wheel disc. I wish I had that. What all is involved in doing your conversion?
Old Apr 9, 2003 | 09:23 AM
redraif's Avatar
:sillylol::sillylol::sillylol:
On the rear conversion...well first you must find a disc rear from a 3rd gen. Prices vary...$400-500, usually. We got a much better deal though! Even had the 3.73s I wanted. The only down side, not a posi. The 88 and newer, or is it 89 and newer...ok anyway...they have good calipers. They are usually more expensive though. The pre 88/89 cars have rear calipers that are prone to get stuck and not brake. I got a 84 rear. Something malfunctions in the inner piston. But there is a $35 rebuilt kit from GM, because this was a recall problem. So we have to rebuilt mine. Also, you will also need the proportioning valve from the disc rear car. Now you can bend you rear brake line to work, or you can just get the one of the donor car. We got it off the donor car, just in case! Get the E brake cables!
Then its a matter of a pretty straight forward swap. Just like any rear end swap. Biggest pain will be the prop valve and bleeding the brakes!
My other big score was the other 84 disc rear for the 82. $40 for the housing, master cylinder, prop valve & cailipers. I had to get axles and new gears, a posi. Now I have to pay someone to set it up...by the end probably $4-500. So either way thats your cost!
So that is the short version. So not a bad conversion at all! Its also pretty easy to upgrade to the 4th gen calipers on our disc housings though. Eventually I will add a posi, but for now this works!
TheExaminer
Sep 6, 2015 11:40 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
Amillionoh7
Sep 5, 2015 11:44 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
