b and m is a bitch....
Old Apr 17, 2003 | 02:58 PM
Xceleratemaro's Avatar
here we go ..i got a megashifter out of an 86 iroc parts car of mine and it was the conselse version. so i thought to my self wow that would be nice to have..i tried to install it today and nothing but hell..1st i had to relocate the holes for the brackets for the shifter...but then when i finally got the shifter mounted right i thought to my self..time to put the cable in so i attemted that and nothing but hell... took oem cable out and hooked up cable up to shifter and tried to hook it up to trans but that was a no go...the end was to short to fit on the trans...PLEASE HELP so take a look at the pic am i missing a part that gose on the trans..?
Old Apr 17, 2003 | 03:03 PM
Kandied91z's Avatar
cable looks alot different than my own so i can't comment on that. mine was actually a bit longer then i liked, having to loop it around seems unecessary. i would have liked a shorter cable.
why did you have to relocate holes? mine came with a bracket that utilized the existing holes and had a new set for the shifter itself. the worst part about my install was dealing with the neutral safety switch. beyond that the minor stiffness the shifter had for the first few days went away and now i love it.
hopefully someone can help you.
Old Apr 17, 2003 | 07:08 PM
no the cable is not that short but the black screw thing is to short
Old Apr 17, 2003 | 07:16 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
everything went pretty smooth and simple in my instalation. For that try moving the two 17mm bolts that attach to the bracket that bolts to your tranny pan. moving the whole cable foward and you can screw that peice back and pop it right in there... everything fits perfect im happy with mine.
Old Apr 17, 2003 | 07:35 PM
well there is only one way the cable will bolt up to the transmisstion and thats not a problem yet...the problem is when you try to hook the black peace to the transmisstion it dose not hook up becouse its to short and will not bolt up to the transmission. so is there different hardwear that will allow it to bolt up to the trans...???\
thanks for your imput chris
Old Apr 17, 2003 | 07:55 PM
i made a pic that may help explain this.. .. but it does fit perfectly
Old Apr 17, 2003 | 09:09 PM
wow i must have got some of you lost....that was perfict but that not the problem...do you see where the black thing that conncets to the transmission? the one you told me to screw all the way to the end? it will not hook up to the the transmission the black thing is too short to put the carrter pin through!!! therefor how do i get a longer peace or what??? how dose your's work?
Old Apr 17, 2003 | 09:41 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
lost too
Ok, I put my megashifter in yesterday in an hour and a half.. so while this is fresh in my mind.. let me put in some input....
If you didn't grab the arm and bracket off the old tranny you need to get those, they are part specific pieces..
other than that it should work..
Old Apr 18, 2003 | 08:37 AM
well the car did not have a tranny so there would be my problme could some body post a pic of what one looks like please? becouse i will make one in shop monday..thanks
Old Apr 18, 2003 | 08:54 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I used the stock cable on the car and hooked it up to the B&M.
Old Apr 18, 2003 | 09:19 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I think this is the piece you are referring too??? The piece on the right..This is the piece you need to use the B&M's cable to mount to the trans..you can order them from B&M seperate. Makes for a much easier install. I had to weld these two pices together to allow the shifter to work properly in my 85 Monte SS...
Old Apr 18, 2003 | 09:54 AM
that would most defintalty be it..i looked on there web sight and i could not find that part......do you know the part #
Old Apr 18, 2003 | 11:03 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Sure do...B&M"S part # is 35498
Old Apr 18, 2003 | 12:40 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
When you use that bracket remember to put the cable into the most forward hole (in the pic the hole on the left) for the 700r4..
Mark is right though, you may be able to use your old cable, check that out, may save some grief.
Old Apr 18, 2003 | 03:13 PM
well im using the old cable right now but i need to fix the problem becouse the trans will not shift into 1st and thats no fun when tring to drift throught the cornners!
Old Apr 18, 2003 | 08:54 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
get a stick
RebelGQ
Jun 13, 2005 12:12 AM
83CAMAROMAN
Jul 25, 2002 08:46 AM
1990 IROCZ
Jun 16, 2001 12:58 AM
