pic of engine
Old Apr 20, 2003 | 12:47 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
pic of engine
Here is a picture of my engine, I just finished installing a Crane cam, Comp 1.5 roller tip rockers, double roller timing chain and gears, 24# SVO injectors, AFPR and Hedman long tube headers.
Old Apr 20, 2003 | 12:51 PM
MdFormula350's Avatar
:hail: :hail:
awesome, darn i spent all my money on exhaust, suspension, and appearance stuff
how many miles on the engine itself?
how long did it take to install all that stuff?
Old Apr 20, 2003 | 12:55 PM
DSLDUDE2001's Avatar
Car: 2001 Camaro SS
Transmission: A4
that is really clean! nice work!
Old Apr 20, 2003 | 01:20 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Thanks for the compliments ! The engine has about 95,000 miles on it, as for how long it took, 4 friggin months!! Due mostly to the fact that I only had 1 day a week to work on it. The cam install and all the other stuff did not take that long but I cleaned or painted everything I could get my hands on. I also ported and polished the plenum, the polishing took some major time. That picture dont even due it justice, I had to keep resizing it to make it fit and it got kinda blurry. The fuel pump died 2 days after I got it going so I barely got to drive it I just ordered the Walboro kit from racetronix so I should have it back on the road shortly.
Old Apr 20, 2003 | 02:52 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Old Apr 20, 2003 | 03:32 PM
WillWood's Avatar
Car: 1966 Volkswagen Beetle
Engine: Flat-4
Transmission: swing axle
Looks good, thats a clean engine and a clean car.:hail:
Old Apr 20, 2003 | 08:18 PM
pskel350's Avatar
looks great
Old Apr 20, 2003 | 08:22 PM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
If that thing runs as good as it looks you ll be flying!
Old Apr 21, 2003 | 12:10 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Hopefully this picture is a little clearer, I resized it differently.
Old Apr 21, 2003 | 12:30 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Looks pretty damn nice! A cam install is on my list for next winter
Old Apr 21, 2003 | 12:46 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
hey
so how did ya end up running the exhaust? true duals?
Old Apr 21, 2003 | 12:50 AM
vulchr's Avatar
N.I.C.E !!!
Old Apr 21, 2003 | 05:50 AM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Very clean! Where'd you get your headers coated? Looks great.
Old Apr 21, 2003 | 07:17 AM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
Looks awesome man! Only thing I see it could use is a nice set of wire looms..
Old Apr 21, 2003 | 08:43 AM
Cliff92Z's Avatar
Car: 1992 Z28
Very nice!
Your plenum and runners look good to. Did you polish them yourself?
Old Apr 21, 2003 | 09:14 AM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
That engine looks sweet!
I like the whole "satin" theme you have going in the engine bay. Looks really sharp!
Old Apr 21, 2003 | 09:26 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
*wipes drewel from mouth*
Old Apr 21, 2003 | 11:39 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
I definately need some wire looms. I'm not sure wich ones I want though, so I just made sure the wires were up out of the way for now. Any suggestions on some good looking looms for centerbolts? Did the plenum and runners myself, and the headers were coated from Hedman. It may not last as long as Jet Hot but money started getting a little tight towards the end and they were only $289 for the headers with the ceramic coating. As for the exhaust, I just had a custom Y pipe made and hooked it to my existing Dynomax setup. The place that made the Y pipe did an excellent job and it was only $110 . Maybe I will post a couple of pictures in the exhaust boards (of the Y pipe) since I will be under the car this weekend doing my fuel pump.
Old Apr 21, 2003 | 02:43 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
nice work there. Keep it up.
Reddeath210
Oct 6, 2015 08:20 AM
project89
Sep 24, 2015 06:38 AM
Linson
Aug 21, 2015 02:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BrianI
Aug 9, 2015 11:52 AM
