Any one have a Pre 85 Trans AM?
Old Apr 23, 2003 | 03:21 PM
devianb's Avatar
I want to see close up shots of the front nose for an idea I have?
Also, are the noses with the blank grills attatched seperately like the other 82-84 noses or are they molded to the nose?
Old Apr 23, 2003 | 03:33 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
teh grills are screwed into the nose and come off...
Old Apr 23, 2003 | 03:35 PM
icebird_1981's Avatar
those vents come right out out they are not molded in, also there is a spot in those vents were u could put a fog like if u want. this is my step dads 84 TA front shot.
Old Apr 23, 2003 | 05:42 PM
devianb's Avatar
What about this nose, do the grill inserts come out too?
Old Apr 23, 2003 | 06:45 PM
bj350hp's Avatar
Car: 1987 Camaro SC
they both come out you can change to eather style
Old Apr 23, 2003 | 08:41 PM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
Yes, but you need to go in from in behind to get them out.
Old Apr 24, 2003 | 01:27 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Heres my 83, not a T/A, but the nose is the same, except for the inserts. My inserts have 6 small phillips screws each, which go in from the front.
Old Apr 24, 2003 | 05:25 AM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
my 86 with an 82 nose on it
Old Apr 24, 2003 | 09:05 AM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
Yep six screws, the "non" vented style attach from behind the front bumper. Pain to get off.
Here is the spot on the "vented" one that you can mount a fog light. I did this to my car.
Later,
bill
just attached it to my plastic reinforcement.
Old Apr 24, 2003 | 10:25 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
currently the closest one of my car i have, one of the grille covers also says trans am on it, i think they are the best looking front ends on third gens
Old Apr 24, 2003 | 10:26 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
is your question answered yet?
Old Apr 24, 2003 | 10:41 AM
ops32's Avatar
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
If not, theres some pictures on my website (link below) that detail how I installed the solid-faced covers after the previous owner took them off. The whole nose should be removed to get access because the solid faced covers install with screws on the reverse side...
Rob
Old Apr 24, 2003 | 02:13 PM
ops32, did u paint those rimz gold?? i have a set and was gunna paint them silver for fun to make them look like new.
Old Apr 24, 2003 | 02:15 PM
never mind u painted them white, how do they look close up, any probelm with paint peeling?? they look good white!
Old Apr 25, 2003 | 12:13 AM
devianb's Avatar
Thanks guys, my question is answered
Old Apr 25, 2003 | 11:14 AM
ops32's Avatar
Thanks! No problems with any paint peeling (yet) but white does show the dirt quicker...
This is the closest shot I have of the rims after painting.
Rob
Old Apr 25, 2003 | 12:00 PM
84TAProject's Avatar
Heres a front shot of my 84 t/a, ground effects were gone when I got it, but it used to be red and black when i got it.
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
TEEZER TA
Aug 30, 2015 06:35 PM
89mulletbird
Aug 12, 2015 07:08 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
