Painted my calipers and polished my accessory bracket, & other pics.
Old May 1, 2003 | 01:54 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Decided to change the front pads with a new set that I had sitting around for 2 year and paint the calipers while I was at it.
Here is the front,
And the rear,
The alternator and bracket,
And here are some misc pictures.
Fuel setup,
And the exhaust.
Old May 1, 2003 | 02:06 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Looking good. Makes me want to do my calipers now too! Not too sure about the bracket- looks half finished
Old May 1, 2003 | 02:11 AM
Zepher's Avatar
Thanks.
Bracket was a quickie, just wanted to see how it would turn out.
I also polished the alternator fan somewhat. I need lower grit paper. Was using 1000grit since that is all I had, and it just didn't get into the metal enough. Maybe some 600 or 400 and then finish up with the 1000. Does that sound right?
Old May 1, 2003 | 05:03 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Yeah start real low and work up. Be interested in seeing the results having just spent 5 hours per wheel on the IROC
Old May 1, 2003 | 05:13 AM
Zepher's Avatar
Ok.
I think I may do the waterpump as well. I may as well just do any part that is exposed and is aluminum.
Old May 1, 2003 | 06:40 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Wow you must have some spare time I'm just jealous as being Married with kid has killed any time spare really!
Ciao
Old May 1, 2003 | 06:47 AM
Dr G's Avatar
Looking good Zepher.
Old May 1, 2003 | 11:08 AM
Zepher's Avatar
I seem to have plenty of time, I just don't seem to use it to it's fullest. I figure that since it's down, I should do as much to it as I can because when it is running again, I am just going to drive and drive and drive. It's been 12 months since I last drove it.
Old May 1, 2003 | 02:39 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
*** I love those wheels.
Nice job on the polishing.
Old May 1, 2003 | 03:03 PM
SLP_GTA's Avatar
screw the car pics Zep
show us the fine young ladies
Oh what is your beer to car work ratio, 6 to 1 seems to be the norm for me
LT1 looks right at home, watch the overspray and keep up the good work
Old May 2, 2003 | 06:00 PM
dsaint1347's Avatar
What kind of fuel setup is that? and where did you get it? Does it help in any way?
oh...calipers look real good.
Old May 2, 2003 | 07:18 PM
A88GTANotchback's Avatar
looks really nice. in time comes good results. and u got them! except the alternator. but hey
Old May 2, 2003 | 07:28 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
that wireing looks like a real headach....
Old May 2, 2003 | 10:34 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
OH MY ***! LOOK AT THAT MESS OF WIRES!!!!
better you than me...
good luck...
Old May 3, 2003 | 01:56 AM
Zepher's Avatar
My car was originally carbed and when I went with TPI I didn't want to drop the gas tank so we installed a Holley 230lph/45psi in-line fuel pump. I was going to go with all braided lines with AN connectors, but I don't know yet if I can get adaptors for that pump. I have an adaptor that will fit the feed end, but the o-ring doesn't seat properly and I don't want a fuel leak.
I am going to go with braided -6AN lines from the hardlines on the front of the car up to the fuel rail on the motor though.
I got the pump from Summit 2 years ago, it was $143 back then.
Old May 3, 2003 | 11:16 AM
MdFormula350's Avatar
nice job, i think i may paint my calipers black come next brake job.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Genopsyde
Nov 11, 2015 10:46 PM
neekolzun
Aug 24, 2015 04:59 PM
kah992
Aug 19, 2015 02:55 PM
