18 inch wheels and tires
Old May 4, 2003 | 12:31 PM
Graboid's Avatar
I have ordered boyd coddington rims, sized 8x18 and 10x18. I plan to wrap them in 235/45 and 275/40 tires. Has someone a pic of a car equipped with this size of tire? Ah, i almost forgot, i am gonna do this on a '89 camaro convertible, the car is lowered by two inches. thanks
Old May 4, 2003 | 12:33 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
thats gonna be a close fit, but when u pull it off, post a pic or tw of them cause i wanna get a set of bazo b4's
Old May 4, 2003 | 12:57 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
235?!?!?!? drop some 255's on that beast
Old May 4, 2003 | 01:29 PM
Graboid's Avatar
235 on 8 inch rim?
would look crappy. i have 8x17 and 9.5x17 with 235/45 and 255/45 now. Therefore i know, that a 235 is just perfect for an 8 inch wide rim.
Old May 4, 2003 | 01:44 PM
Engine: peanut LB9
imo- 245/40 in the front
and 275/40 in the rear
Old May 4, 2003 | 06:01 PM
Topless91RS's Avatar
Car: 1991 Camaro RS Vert
Engine: 305 (L03)
Transmission: 700 R4
i have 18"x9.5" on all 4 corners of my car, they are 2k C5 vette wheels. Kandied91z has 18x9.5 and 18x10 or 10.5 on his Z.
Old May 4, 2003 | 09:25 PM
Kandied91z's Avatar
anything wider then a 1-1/2" is really noticeable in rims, not my first choice but i suppose you can make it work.
personally i think a 245 would be better up front but you have to factor in the profile as well. definately will have a noticeable difference with that setup.
i'm running 275/35 on a 9.5/18 front and a 295/35 on a 10.5/18 rear and everything works well for me. just make sure that whatever combo you go with that you try to keep the overall stock dimension of the tire and you should be fine.
my new setup is almost identical to my old 245/50/16 on the stock z rims so not much changed in the transition besides a harder tire to move and tracking the road alot more.
good luck.
Old May 5, 2003 | 08:03 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
In my opinion your tire choices are too narrow for those wheel widths. 245s come STOCK on an 8" wheel, and the sidewall profile is pretty straight. If you put a 235 on, it's going to look funny. Likewise, a 275 on a 10" wheel is pretty small. Stock 9" wheels come with 275 tires, and like with the 245s, it makes for a pretty straight sidewall. My buddy has some 225s on 8" wheels on his BMW and it looks silly. It reminds me of those lowriders that stick a 155 width tire on an 8" wide wheel.
Old May 5, 2003 | 09:59 AM
Nazzz28's Avatar
Car: 91 z28
Most of the stock thirdgens come with a wheel and tire combo that have a diameter of 25.6”. If you are using 18x8 front wheels I would use a 245/40/18 tire since it has a diameter of 25.71”. For the rear 18x10” wheel a 275/35/18 tire would give you a diameter of 25.58”. However, if you wanted something a little taller and wider you could use a 285/35/18 with a diameter of 25.85”.
You could use the sizes that you have listed but if you run a 275/40/18 on the rear it would have a diameter of 26.66” and could possibly cause some clearance issues, especially if your car is lowered.
All of these tire size should be safe to run on the width of wheels that you listed.
I am going with 255/45/17’s on my 17x8 fronts and 285/40/17’s on the 17x9.5 rear wheels that I finally got in.
Old May 5, 2003 | 11:51 AM
Graboid's Avatar
pic's?
has anyone of you guys pictures of your rims/tires/car?
Old May 5, 2003 | 12:46 PM
Dan88IrocZ's Avatar
235 is skinny and will look funny IMO.
I'd do atleast 245 on the front.
Put a silver Iroc-z decal on your door and make that baby stand out even more!:hail:
Old May 5, 2003 | 12:50 PM
Graboid's Avatar
iroc-z decal?
i will be aware of putting a silver iroc-z decal on the door of a RS....
Nazzz28's Avatar
Car: 91 z28
I'll have some pictures of my car in about a month. I finally got
my centerline wheels in last week (after 6 weeks), and am
currently working on some cooling issues. After I touch up the
paint I will be putting the new wheels on and will take some pics.
By the way nice car, what wheels were on it in those pictures.
Old May 5, 2003 | 12:53 PM
Graboid's Avatar
nazzz28,
if you mean my car, they are billetspecialties gtx series (dunno exact type, look not to good anyway imo)8 and 9.5x17
Old May 5, 2003 | 12:59 PM
Nazzz28's Avatar
Car: 91 z28
Graboid,
I was talking about your car. What boyd wheels are you going
with, there are some pretty nice ones.
Old May 5, 2003 | 01:01 PM
Graboid's Avatar
dan88,
i buy only japanese tires (bridgestone/yokohama/falken etc.) because they look wider than Us or european products. A goodyear 245 looks like an yokohama 235. That's because the japs make the profile 235mm wide, while the rest of the world make the whole thing 235mm.
Old May 5, 2003 | 01:03 PM
Graboid's Avatar
nazzz28,
what do you mean to them?
Old May 5, 2003 | 01:20 PM
Nazzz28's Avatar
Car: 91 z28
Those are nice. I always pictured that style more on a old
Impala, lowered down, and in the g-machine style. However, I
think in the 18" size they will look pretty nice on your car.
Old May 5, 2003 | 01:30 PM
Graboid's Avatar
nazz28,
i was on a car meeting yesterday, i saw them in size 8x19, and 10x20 on a '57 bel air. I just checked the photos i made and they helped me make my decision on what size i should choose. They were wrapped in 225 and 275's, and it looked great. If anyone doubts that, i'll be glad to post the pics
Old May 5, 2003 | 02:06 PM
nolanr0413's Avatar
Car: Trans am
18 inch irocs kick a$$ get a set of them .
Old May 5, 2003 | 02:17 PM
Graboid's Avatar
yes, they do, but 8 inch wide rims in the back are for sissies....
Old May 5, 2003 | 02:33 PM
Engine: peanut LB9
i agre with that stagement. i hate the idea that they only come 8" wide. but the rms i want are 8.5" wide, i wish therear came a little bigger.
Old May 5, 2003 | 02:50 PM
Engine: 305 (L03)
I posted pics on your other post...
https://www.thirdgen.org/techbb2/sho...hreadid=177534
Old May 5, 2003 | 08:17 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
i just took off my zr1's with the17x11's out back for the zo6's 18x9.5 18.10.5 275/35/18 and 295/35/18.the 315/35/17's look way more beefier.but i get way more looks now,not that i care,cuz i got them for me.
irocdan's Avatar
Car: 88 Iroc vert
side
Old May 5, 2003 | 08:18 PM
irocdan's Avatar
Car: 88 Iroc vert
rear,this rear shot looks very crappy to me,tires look skinny in the pic
Old May 5, 2003 | 08:19 PM
irocdan's Avatar
Car: 88 Iroc vert
this is what my ride looked like before
Old May 5, 2003 | 08:41 PM
Engine: peanut LB9
has anybody ever done a 17" in the front with 18" in the rear?
Old May 5, 2003 | 08:45 PM
irocdan's Avatar
Car: 88 Iroc vert
thats what the stock zo6's are.some people say your suspention should be adjusted to the wheel difference,but who am i?
Old May 5, 2003 | 09:09 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
Hey IrocDan, What size wheel spacers did you run on your car with the Z06 wheels. What are the offsets on the Z06 wheels that you got?
Old May 6, 2003 | 02:16 AM
Kandied91z's Avatar
i'd also like to know............there is no possible way i could get mine to tuck in that close without some inner fender work to bring it in some, let alone even begin to turn if i dropped the front that low.
looks really nice, i'd like some more details to know exactly what you did as i would like mine to fit that nice.
Old May 6, 2003 | 07:23 PM
CGCBandit's Avatar
:hail: :hail: what size spacers are you running with? and where did you get the spacers from?:hail: :hail:
Old May 7, 2003 | 04:06 PM
irocdan's Avatar
Car: 88 Iroc vert
from www.wheeladapters.com 2 1/4" front 1 1/4" rears,you can get them from www.skulte.com too
Old May 7, 2003 | 06:32 PM
CGCBandit's Avatar
Thanks man, those wheels look killer
Old May 7, 2003 | 07:51 PM
Kandied91z's Avatar
so what's the offset and make..........?
i have the same front adapter size with 9.5 and there is no way possible to bring them in that close without body modification
did you roll the fenders and massage the inner rear wells?
Old May 8, 2003 | 10:00 AM
irocdan's Avatar
Car: 88 Iroc vert
i did roll them but i didnt really need to,just wanted to.the rears need to,i forget the offsets, but i'll post it
Old May 8, 2003 | 09:17 PM
Mr. Z06's Avatar
Hmmmm....those 295/35/18's look as skinny as my 255/45/18......strange??
Tommy
Old May 8, 2003 | 09:21 PM
irocdan's Avatar
Car: 88 Iroc vert
tell me about it....i guess i'm used to mt 315's i had on with my zr1's
Old May 8, 2003 | 11:49 PM
Mr. Z06's Avatar
Hmmm...irocdan, this is really bothering me! Your tires should be much wider! What size rim are you using? I have 18x8. Man, those 17's look awesome.
Tommy
Old May 9, 2003 | 03:40 AM
Kandied91z's Avatar
now the rears were able to come in alot since it was a 9.5 rim, however the backs cannot come in any further without some serious inner fender work. they are 10.5 295/35.
i would like to know how you got yours to work so nicely.
Old May 9, 2003 | 11:26 AM
Graboid's Avatar
made my decision
So, although i doubt that it is interesting for anyone of you guys, let me say to you that i have ordered the tires for my 8 and 10x18 boyd wheels. They will be wrapped in 225/45's and 275/40 bridgestone S-O3. I will post pics as soon they are on the car.
Old May 9, 2003 | 05:45 PM
  #42
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
Here's a question to all of you guys running bigger than stock wheels. How the heck do you turn?If I do anything than a partial turn on my 16's I am rubbing BAD. If I am backing up and pulling into a spot it rubs so bad my car stops and I have to REV it to get it to move. That is too scary fitting into a sport. I would love to run 17's or 18's but I can't even imagine another 1.5 inch width. Heck a U turn now is a PITA, I can't even imagine doing one than.
Any help?
Old May 9, 2003 | 07:50 PM
  #43
Kandied91z's Avatar
i have no problems at all but i also have measured out and fitted the wheels to work right.
15-20 it doesn't matter, the width of the rim and your tire choice is what makes the difference. it all depends on what your trying to do.
Old May 9, 2003 | 11:30 PM
  #44
HotRod's Avatar
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
Figured I would add my personal experiance as well. I am running 18x9.5" C5 wheels all the way around with a 275/35/18 tire. The front and rear spacers were 2" but the C5 brakes bring the front out another .300" and make them look better imho and I am changing to 2.5" spacers in the rear. When these tires wear out I am going to run 295/35/18s on all four corners. By the way I am lowered with Eibach sportlines and everything on the suspension is fresh. I have no rubbing and can turn as tight as I like. I think the spacing has more to do with it than anything because my old 255/45/17s used to rub and these don't,
Tyler
Old May 10, 2003 | 04:04 AM
  #45
Kandied91z's Avatar
i'd like to see pictures.
a 2" sportline drop would not work with my 275/35 no matter how hard i tried.
Old May 10, 2003 | 08:42 AM
  #46
nosaint's Avatar
Car: 1986 Trans Am
I put 17" X 9.5" with 275/40's all around. I wish i would of went with a larger tire as I like a bit of a bulge. Car has a 2" bell tech drop in front.
Old May 10, 2003 | 12:59 PM
  #47
HotRod's Avatar
Car: 87 GTA
I wish I had a digital camera to take some pictures with. Once I get some normal pictures I will scan them in for you. Kandied91z
I think there is a small diferance between the Camaro fenders and the Firebird fenders which may be why mine works? Anyway I only have about a 1/2" of clearance between my tires and the struts with the 2" spacers and 18x9.5 C5 wheels. I tried putting on a buddies 295/35/18 on a Y2K vette wheel and it hit the strut untill I converted to the C5 brakes (extra .300" clearance) and it appears to clear in but I did not drive it more than maybee a mile like that so it may scrape on some bumps. Anyway, I will try to get pictures...
Tyler
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
overdriv
Aug 20, 2015 03:52 PM
forstral
Aug 19, 2015 03:20 PM
