Cleaning Engine Bay - Help!!
Old May 15, 2003 | 01:53 AM
Firebirdjoe's Avatar
Car: 1987 Pontiac Firebird 82k miles
Engine: 2.8 V-6 (173 c.i.)
Hey everyone, Now I'm not the brightest when it comes to car mechanics, but I like cleaning cars... It's what I do for a living, seriously
Anyways, me and a friend are still in the process of rebuilding my engine which is a 3.1 V-6. I found that carb cleaner worked great for cleaning out my throttle and plentum. Tonight I used it to clean parts of the engine bay to get the dirt and black gunk off. It seemed to work very well. I did spray some over a few sensor parts that are still plugged in. I didn't get anything into the water jackets and other open areas.
Now my question is this, the engine bay looks really clean, but did I do it the stupid way where I could have screwed something up?
Thanks for any help, Firebirdjoe
Old May 15, 2003 | 01:58 AM
BTS88IROC's Avatar
You've ruined everything!
But no seriously, you should be okay. Have you driven the car since then? Anything act funny??
Old May 15, 2003 | 02:02 AM
LOL... no the top half of the engine is still in the rebuild stage. I have the heads at shop getting milled, I am going to pick them up tomorrow. It should be another week before we fire it up. I have a problem of doing things before thinking
Old May 15, 2003 | 02:05 AM
Your can check out pics of my car and the rebuild process here
Old May 15, 2003 | 03:00 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Carb cleaner will take off the paint, won't it? Or am I thinking of brake parts cleaner.
Old May 15, 2003 | 04:07 AM
BTS88IROC's Avatar
I don't think either will actually. I know brake fluid itself will destroy paint, but I'm pretty sure the cleaners won't.
Old May 15, 2003 | 06:31 AM
0103837's Avatar
Car: Camaro
Engine: Gas
Transmission: Automatic
I dont think you've messed anything up, it just pretty expensive to clean every part with carb cleaner. Thats why it is not recommended...
Old May 15, 2003 | 11:45 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I think I heard that carb cleaner is not good to use in the throttle body. Something to do with a coating on the inside.
I play it safe and use throttle body cleaner.
Old May 15, 2003 | 12:07 PM
91blackgta's Avatar
its because throttle body cleaner also lubricates.
Old May 15, 2003 | 12:47 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I can speak from experience on the brake fluid thing.......
Old May 15, 2003 | 03:00 PM
Mylilbowtie's Avatar
Car: 1988 Iroc-Z / 1992 RS
Engine: 5.7 TPI / L03 TBI
Transmission: 700r-4 / 700r-4
Axle/Gears: 9 bolt 2.77 posi / 10 bolt 2.73
Dont go to crazy with that carb cleaner. It will eat paint (ask me how I know) It will dull it really bad and if the paint isnt all that good it will bubble it up and it will flake off. I like simple green myself for grease and stuff that has paint under it. Works pretty good and doesnt mess the paint up.
Old May 15, 2003 | 03:11 PM
Old May 16, 2003 | 08:33 AM
91blackgta's Avatar
Simple Green works great. I used it on all my tpi parts when i was rebuilding. It cuts the grease well. It's the bizatch.
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
