Getting sticky crap off paint?
Old May 29, 2003 | 10:53 PM
stiers's Avatar
I removed all the badging and the door trim off my car, I am going for a stealth look, but I can't seem to figure out how to get the sticky crap off the paint? I tried nail polish remover and googone but neither one worked. Any ideas? I already filled the holes in the ground effects and am smoothing it over to give it a stealth look. Should I just sand it off since the car is getting painted anyway?
Old May 30, 2003 | 02:26 AM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
can always using rubbing compound, will work...
Old May 30, 2003 | 03:03 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
spray brake cleaner on a rag and rub
Old May 30, 2003 | 07:28 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
3m makes a decal/molding adhesive remover. It's NASTY stuff though. It makes me sick when I use it, but it is an option if you can't get brake cleaner to work.
Old May 30, 2003 | 08:37 AM
DaGoat's Avatar
The people that make PB Blaster have a product called DSR, Decal and Sticker Rremover. I used it on the adhesive underneath the door mouldings and it worked wonders. Should be able to find the stuff at any parts stores. I found mine at Napa.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
bubbaz28
Sep 18, 2015 02:09 PM
Randomtask2
Sep 7, 2015 05:06 PM
Stryker412
Sep 7, 2015 09:11 AM
