just painted car.. kind of rough
I just painted my car the other day outside. Overall it came out good and it shiny ut it has a rough feel to it. How should I go about buffing and sanding it? Will it make the car a lot shinier. How long should I wait before doing this?
Car: 1990 Formula
Transmission: WC T5
Start with 600 if it is that rough otherwise start with 1000 grit then 1500 then 2000. Then buff with buffer/compound then glazing compound.
Start TODAY! If it is urethane after 3-4 days you will have to sand your ***** off to sand it flat.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I used 2000 grit on mine (enamel)....it's a pretty rough paint to spray.....and it laid kind of rough too...as you can tell....the sandpaper does it all...
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i did my car with 1500 then 2000 then 4000, all on a d/a. i wet sanded the day after we painted it. i used the 3M perfect it III compound and machine glaze
Engine: 5.7
Originally posted by Ragtop89
84customZ28, do you have any close up pics of the 81 fender louvers?
How hard was it to install those?
They look pretty damn slick!
here ya go man....most of it's right here...I'll be posting a new thread when I get all of the pictures back..
https://www.thirdgen.org/techbb2/sho...Fender+Louvers
Engine: 5.7
4000 grit? Is that in a liquid form? Did you use base/clear? How do you like the perfect it III by 3M? I really like that stuff...we get great results with it everytime..
Car: 84 camaro Z28
Engine: 434sbc
the 2000 and 4000 are both for the D/A. they are like a sponge. you put them in water and then ring them put. theyhave a velcro backing so it sticks to the D/A. once you use the 4000, you see the shine start to come back to the paint.
i used urethane. yes i used base/ clear coat.
the perfect it III system is amazing. i use it at work and on my own vehicles. i highly recommend it.
Engine: 5.7
[QUOTE]the 2000 and 4000 are both for the D/A.[/QUOT
I've never seen 4000 grit sandpaper before. I can go up and buy 2000 grit wetsand paper (by hand)....I've just never seen 4000 grit before...
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
twice.
seriously though they wouldnt fit your car.... it would look sooo......wrong.
Engine: 5.7
Originally posted by MrDude_1
steve, you put thoes on your car, and i will smack you.
twice.
twice.
ur opinion....I think they look good....
Car: 91 Camaro Vert
but steve has a vert... and the verts are flatter all around... i think its because you see the flat trunk, side top covers, ect.....
i think they would clash on his car....
the coupe has more of a curve to it because of the roof and rear...
