what the hell is this stuff
Old Oct 30, 2003 | 03:14 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
alright i just got done stripping all my wheels and one of them looks very ugly, i though the clear coat just didn't come off all the way but it did. What are these white lines on my rims, i dont want to reclear coat my rims with this stuff of them.
if you are wondering if this is the only rim with it, yes it is the only rim with this stuff on it. If you know what it is, how do i get rid of it? Thanks in advance guys.
Shane
Old Oct 30, 2003 | 03:19 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
there were small cuts in your clear coat originally and what you see is the oxidation of the base metal. When I polished my rims the oxidation just sanded right off. If you are not polishing, I would try something like a gray scotch bright pad.
Old Oct 30, 2003 | 03:29 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
so it will come off really easily. Like if i use a Scrub Pad, like the back of a spong, it will get it off? Or do i have to sand those grouves out of the metal to get to the oxidation?
Old Oct 30, 2003 | 03:41 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I don't know if an ordinary scrub pad will do it. the gray scotch brite pads are a abrasive pad sold just as such(like at home depot with the sand paper), instead of sand paper. I would try to sand "with the grooves" so that it can get inbetween. I have not actually done this, however, I know when I polished my wheels that oxidation came off pretty quick with the sand paper.
Old Oct 30, 2003 | 03:42 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Its hard to say. Hit it with some metal polish and see if that gets rid of it. If not, its left over clear coat. Even though it may seem that all the clear is removed, its probably not.
Old Oct 30, 2003 | 03:44 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
so its a gray scrub pad sold near the sandpaper in homedepot? Alright thats alot. Now for a different question for you.
shuld i just polish my wheels or should i reclear coat them? I mean reclear coating them will be ok but i have plenty of aluminum polish.
Old Oct 30, 2003 | 07:10 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I would first try the alum polish like 88 WS6 TransAm GTA said if that doesn't work then I would try the gray scrubbie, then polish.
Old Oct 30, 2003 | 07:12 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
ok thanks guys, i'll try it tomorow becuase by the time my wheels dried from being rinsed it was too darkt o trey anything, someone told me before that steel wool might work also, is this true?, i didn't think it would get in the grouves though.
Old Oct 30, 2003 | 07:43 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
steel wool will work some but not as great as a scotch brite pad. but give it a try. i use steel wool to clean my rims and it doesnt harm them so whats the loss in trying?
Old Oct 30, 2003 | 09:59 PM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
What product did you use exactly to get the clear off.
Old Oct 31, 2003 | 03:24 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Aircraft Remover, its the bottle thatyou can get at autozone for like $7.49. You apply it with a brush.
Old Oct 31, 2003 | 11:54 PM
onebinky's Avatar
The only downside to using an abrasive is that it will change the texture and sheen of that specific area. Before I decided I was going to polish mine, I used a small diameter wooden dowel rod to rub the oxidation off. It's alot softer than the aluminum, but still harder than the oxidation so it'll take it off. It's kind of a slow process, but it worked alright. After you do that, follow up with some polish on the entire wheel.
If you decide on the abrasive method, the steel wool is the equivelant to about 1000 grit sandpaper. And make sure you stay with the grooves like novass said, or you'll have a shiny flat spot surrounded by grooved dull gray aluminum
EDIT: After studying your pics for a min, I don't see any grooves in the aluminum. If that's the case, it should make it a bit easier for you.
Old Nov 1, 2003 | 06:56 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
yeah there are groves in the aluminum. I'kll try yoiur wooden dowel idea, sounds like something i would do wrather than take steel wool and scratch my rims. We have a bunch of dowels in the tool shed so this might be my lucky day. Thanks alot guys, I'll tell you and show you how it came out.
I just have to get over my soar throat and fever before going outside todo that.
Thanks again.
Old Nov 1, 2003 | 07:35 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Axle/Gears: 3.70 Posi BW 9 Bolt
oh damn all four of my 14" american racing rims have that stuff i thought it was fungus or sumthin. the wheels came with my car when i bought them so i got no idea where theyve been.
Old Nov 17, 2003 | 08:47 AM
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
I used steel wool soaked with windex ( blue window cleaner ) on an old set of aluminum mags and it worked great.
Old Nov 17, 2003 | 03:54 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Well after many seesions with my BlueMagic Metal Polish. I have abosolutely no success story to tell you guys. This shizz will not come off one bit. Its not clear coat becuase if you rub it with your fingernail you dont feel anything. But it just will not come off one bit. Any new ideas guys, cause this metal polish says ont he back, "removes oxidation instantly," well when is it gonna come off. i need more help guys.
Old Nov 18, 2003 | 07:57 AM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Wet sand it with 1500grit and then finish it off with 2000 grit and watch that beeyatch shine!
Rocket-Doc
Nov 14, 2015 02:08 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
aaron7
Sep 30, 2015 09:15 AM
