adding fog lights
Old Nov 12, 2003 | 09:24 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
adding fog lights
i want to add foglights to my 91 formula, i was wondering what the best route to take would be, either getting all of the stock lights and making it look stock, or just getting a set of generic lights
what do you guys think ?
Old Nov 13, 2003 | 12:01 AM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
fog lights?
I used pilot brand on my 91' T/A and I also gutted the nose little to add day runners as well!...but if you can figure out how to add some relays then your set to go with out running down your battery!
Old Nov 13, 2003 | 03:29 PM
Car: 91 formula
Transmission: t5
after taking off the panel wehre the hatch relesae switch is , tehre is wires for the switch for the fog lights.... does that mean that there is wires down where the fogs should be incase tehy were added?
Old Nov 14, 2003 | 01:34 AM
sheltonw3's Avatar
Engine: Classified
its hard to say?....you might need a GM manual for your specific make and model to be sure!...if there are wires there, you could follow them to see if there is waiting relay to add fog lights?...but if there is no relay you can get relays added to the existing wiring from your parking lights and add an original switch from a junked 91' t/a with foglights already intergrated and follow the harness off of that car?...if you can find a junked 91-92 bird?
Old Nov 14, 2003 | 10:54 AM
MdFormula350's Avatar
stock 91 - 92 fog lights.
mine was prewired also.
just needs to bolt in the front light assemblies, plug the connectors up.
then on the inside, i put in the fuse for them in the panel, added the relay which the connector was under the drivers side dash, and then i bought a used 3 switch panel for a clean install and just plug the switch into the connector after untapping it.
Old Nov 14, 2003 | 03:33 PM
Car: 91 formula
Transmission: t5
ok thanks for the picuture and i am asking all this because there is a 92 bird with them in teh yard and i was wondering if it was worth my time
and i cna always just pull the relay out of that bird and add it to mine.
Old Nov 15, 2003 | 10:34 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
Re: adding fog lights
i have the crappy off the shelf ones from pep boys, and you can barely tell the difference. they were like $24.99, and work great.
unless you know EXACTLY what to look for, you wouldn't know they aren't stock.
-brian
Old Nov 15, 2003 | 04:12 PM
Car: 91 formula
Transmission: t5
when you say add the relay... do you mean add the wires going from the fuse block to the fog lights or the wires goign from the switch to the fuse block ?
and what color wires are on the plug that the wires connect to go run to the fog lights from under the dash, i saw a connector that was loose that had a green and grey wires in it ? would that be the one ?
Old Nov 16, 2003 | 02:26 PM
add the relay means, buy the relay and plug it in the connector under the drivers side dash near the fuse block.
your car seems to be just like mine, where as its completely wired up and ready to go, just plus in the switch, fog lights, relay, and fuse and it sohuld work like mine did.
6 dollar relay i think it was, its smaller than the fan relays.
GTAman
Mar 15, 2019 11:40 AM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
SlowAZ28
Members Camaros
Aug 31, 2015 07:53 PM
tealman92
Exterior Parts for Sale
Aug 27, 2015 11:21 AM
mustangman65_79
Aug 12, 2015 06:39 AM
