peuter headlights anyone?
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
A lot of people have the painted headlight pockets and my car has been repainted silver and does not have it and i intend to keep it that way. I thought it would be a nice contrast if i could find a set of head lights that had a peuter backing then you would get that black look from the lights while the car is off. Dont really care what modifications id have to do with the brackets that can all be figured out. My buddy mentioned something like this and ive never even seen lights like it before but i think it would be really cool. Would prefer to stay with the split high and low beams but if necessary would go to a single panel.
Car: 1990 Camaro
Engine: 355ci
awwwww are you kidding? If anyone has those and doesnt want em if theyre in good shape id seriously consider buying them and id also be willing to trade em the stock ones if thats what they want in there. Man that sounds perfect!!! damn it just my luck eh
anyone else got any ideas?
anyone else got any ideas? Senior Member
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
I dont know if this would work, but VHT Niteshades, i think is the name of it, its like tint in a bottle for lights, when you turn the light on its supposed to be like a normal light, then when off it looks like a blackout. Ive never used the stuff tho. It can be found in summit or jegs. Like 10 bucks a can.
Kevin
edit: here is more info bout it
http://www.autocarparts.com/part/1291/
Kevin
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Originally posted by Kandied91z
jcwhitney use to sell replacement lights for our cars that had a black backing so it was dark when they were off.....sadly they don't anymore.
Car: 1990 Camaro
Engine: 355ci
yeah there were a few factory cars that had them. i've seen alot of them on the older 4wd s10 and blazers back in 91-92 era.
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
I actually started looking around for them but can't find anything! Just a little more info; they were just like normal headlights in every way, except the lens had a black tint, so your headlights would look completely black when off, then light up normally.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you COULD get thoes cheap H4 conversion housings and seperate the back from the lense... paint it all, and put it back together... however....
1.. its reflective for a reason... your lights wont work nearly as well like that.
2. you cant put a higher watt bulb in thoes housings... they melt if you do.
if you try it and deem the amount and pattern of light they give off acceptable, you can try that... but it sounds like a bad idea to me.
Car: 1990 Camaro
Engine: 355ci
Car: 91 Camaro Vert
hows this?
buy a big LCD panel.
when current is applied its either clear or dark..... so you can turn it on or off........ when the lights off, have it dark, when the lights on have it clear....
athough, thats a costly solution.
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
Originally posted by JR92z28
A: Where did you get your lights?
B: By the way, NICE CAR!
C: Any times yet?
D: Thanks,
C: Any times yet?
D: Thanks,
- These guys are "O-K"B: Thank you
C: No, it's shabby on the bottom end, but can do 145mph all day long, so it's not really a 1/4 mile car
D: You're welcome
EDIT: Here's a direct link to the product: http://www.demandmotorsports.com/Detail.bok?no=490
RE-EDIT: On the inner pair, I removed he lamp glove which is "blinding" bright, but it's on the high beams anyway. When off, it looks MUCH better this way like new cars with a seperate high/low bulb. For example, Ken's red convertable is awesome, and he has the same headlights, but it doesn't look as good with all four lamps having the lamp glove (Your car kicks as_S Ken, just my opinion on the lights). I'm real happy with mine.
Car: 88' Iroc-Z
Engine: LQ9
I HAD THOSE!!! they're black when off and white when on! yeah they were cool as ****! they're made by philips im pretty sure. i ordered them through jc whitney about 3-4 years ago $15 a piece but well worth it.
UPDATE: just went and grabbed one they are called the Philips Color Clear Lights. I'm searching on where to locate them for you all.
Car: 1990 Camaro
Engine: 355ci
Car: 88' Iroc-Z
Engine: LQ9
ok after some searching ive only found one lead... i emailed jcwhitney to see if they can help us out. but the lead i found was off of a Delorean message board philips told them that this place and jcwhitney are two places to get them.
Keystone Automotive Warehouse 800-233-8321
im waiting on a response from jcwhitney and philips. so lets just hope ill call keystone tomorrow.
Car: 88' Iroc-Z
Engine: LQ9
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
keystone is a pretty big supplier...i used to work at a garage/store and we used to carry some of their products in our store. they should be able to help ya out
Car: 1990 Camaro
Engine: 355ci
Well Canadian Tire has a thing where i can order through keystone and i have their catalogue but nothing by phillips is in here. I also sent philips an e-mail and am waiting to hear what they say. I really hope i can find a set (ill probably buy 2 sets if i find em) because this is exactly what im looking for to go with the custom look that i will have on the front of my car.
Car: 88' Iroc-Z
Engine: LQ9
they do give a really nice look, i have a blacked out iroc and they set it apart but that iroc is currently in the process of getting a new engine, interior, and transmission.
Car: 88' Iroc-Z
Engine: LQ9
Alright i got an email back from JcWhitney this is what he said:
Dear Customer,
I researched through our resources and we no longer carry that
particular item. You can get them from a website called.
www.classicindustries.com
Thanks,
Jessy,
JC Whitney Customer Service
http://www.jcwhitney.com
i havent had any luck finding them on classicundustries but maybe you will, but i'll continue my search
Dear Customer,
Thanks,
Jessy,
Car: 88' Iroc-Z
Engine: LQ9
well guys this is my update:
Philips Lighting answer:
Mr. Taylor,
Due to lack of consumer demand, we discontinued production and sales of
these bulbs a few years ago. We no longer have stock availible.
Philips Automotive Lighting
and classic indstries doesnt have them either. they told me to go to www.hemmers.com havent done it yet though.
Mr. Taylor,
