Why Formula nose got Bigger holes?
Old Mar 15, 2004 | 11:07 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
what's the reason?
Big Holes :
Little Holes:
Old Mar 15, 2004 | 11:09 PM
Calderone's Avatar
Car: 87 Vette
complete holes
complete holes
Old Mar 15, 2004 | 11:11 PM
Calderone's Avatar
Car: 87 Vette
incomplete
incomplete holes :
THE GREY ONE ABOVE ISNT A FORMULA .....BUT ITS A FORMULA NOSE
Old Mar 16, 2004 | 05:01 PM
devianb's Avatar
I believe the actually opening size is the same, but the TA bumper has more material and goes in deeper than the Formula bumper giving the appearance that the Formula openings look larger.
Old Mar 16, 2004 | 08:46 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
No formulas came with foglights... That is the front fascia for a non-foglight-equipped formula or base-model firebird (the ones with the foglights are part of the W68 Aero Package for 91-92 birds)...
Old Mar 16, 2004 | 11:36 PM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
YO "PEEP" this!.....................
My customized nose job!...4 pilots fog lights and I'm read't go!
Old Mar 18, 2004 | 02:37 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
Hey Shelton...is your car a TA? Did you cut out bigger holes...If so, can you enlighten me as to how you did it?
Old Mar 19, 2004 | 12:27 AM
sheltonw3's Avatar
Engine: Classified
I used a spring loaded cutting tool and a magnum cutting knife the open up on both sides of the license plate and it gave me more room to add 2 more foglights and the engine gets more air flow ,so there is enough room to work around ,but I did cut a little into the impact absorber too,to secure the second set of lights ,but it does get alot of attention!
83 Crossfire TA
Jan 3, 2016 01:26 PM
90formulaVortec
Sep 8, 2015 12:42 AM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
90formulaVortec
Sep 7, 2015 06:54 PM
Formula_88AE
Sep 3, 2015 01:47 PM
