LED Turn Signal Bulbs?
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I went to autozone today....looked through some of their bulbs...and they have LED parking lamp/turn signal bulbs (like 10 LED's per bulb).....they were $17 bucks for 2 bulbs...pretty pricey. I was just wondering if anyone has installed a set in there turn signals.....I'd like to get my parking lamps/turn signals a bit brighter...and thought this would be an easy way of doing it.
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
i saw those as well last week. A little to pricey for me, il stick wit 5 bucks for 2 bulbs
Engine: 5.7
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
I have LED's installed in my front turn signals, front side markers, fog lights, both headlights, rear triangular side markers, brakes lights, rear turn signals, back up lights, and license plate lights.
Since you know the "white" LED's have almost a purple or blue tint depending on brand, it's very important to match the color of LED to the enclosure. White LED's in the brake lights looked like ***, but red ones look much better. Similarly for the turn signals, white LED's made them look dull and green, therefore an amber LED set is required to make them look decent/bright. White LED's were used for the license plate, back up lights, side markers (clear), and front turn signals (clear). I'll grab a pic in a sec of my front turn signals.
EDIT: Here are some pictures;
Front angle shot;
Front close up;
Side Marker close up;
Aux LED in foglight;
LED in headlights;
I think I'll be changing the front to a rich amber like on the new Vettes, a little less "r!cey"....
Front angle shot;
Front close up;
LED in headlights;
Engine: 5.7
Engine: 5.7
how about the LED bulbs on this site? [url]
http://www.autolumination.com/
this site has TONs!.....which set should I get? 1157 "24 LED" type or the "eagle eye" 1157 type? What did you go with TPIROC? I want my parking lamps to look like the 4th gens and the vette's...
Car: Camaro
Engine: 3800
I just got some 194 replacement bulbs from SuperBrightLEDs and replaced the blinkers inside with green ones like stock.. and the dummy lights with red ones to match. I got the 6 LED per bulb ones and they are VERY bright. Love it.
Question about the exterior lights though.. are the lenses evenly filled up with the light? Or is it a super bright dot where the LEDs are and some light around it? Can't tell that well with the pictures b/c you can't tell how much light the camera is actually picking up. I mean.. I took some pictures of my car when it was almost dark with the 'Night' setting and my amber parking lights looked killer, but they look like crap in real life... which is why I was wanting brighter ones. But.. yea.. how evenly does the LED 1157 "bulb" fill up the light?
Also found some that had LEDs facing forward and some of them facing 90* to the other ones. Seems like those would be the ones to get for the tail lights if the others are just a bright dot with some light around it. Little on the .... expensive side though. https://www.netdisty.net/ds/aut1157/default.asp Haven't read about it much just thought it was a good idea to have LEDs that were sideways.
-Bud
-Bud
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
Are you going to buy LED bulbs for the parking lights/turn signals?
Engine: 5.7
i need 1157's for my parking/turn signals though right?
is there a big difference between the "eagle eyes" and the "24 LED" bulbs? It says that the "Eagle Eyes are the most powerful forward facing LEDS"...I'm about to order...and if anyone knows...that would be a plus..
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
do these bulbs have the same resistance as a refular filament bulb? I was wondering because if the resistance in the circuit changes it will change the speed at which the lights flash. I need to put brighter bulbs in my car because with my blackouts on my tals look dim and I would like to brighten it up back there
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Is there a big difference between the ones that are $7 and $64... I imagine theres some but I cant imagine a $57 difference in illumination quality...
Engine: 5.7
well...I installed my LED bulbs in my turn/parking lights...(1157's) and now, they will not blink....they just stay on. Does anyone know why???????
Car: Camaro
Engine: 3800
Stupid idea.. but .... you turned all the way them after plugging them in right? I replaced the bulbs in my parking lights and the blinkers weren't working... the lights turned on but didnt blink. Arrows inside didnt blink either.... turning the bulbs was a stupid mistake on my part... just making sure you didnt do that same
-Bud
-Bud
thats what I was afraid of the resistance in the bulbs is different than the stock ones. That causes te flasher to have a different amperage and not blink so either you replace the flasher with the right one, dont know which one though or put resistors inline with the bulb wiring to get the resistance back to what it needs to be.
Engine: 5.7
I just found out that I need an "equalizer" for them to work properly...they are 7 bucks each...I just bought them.....when I get them..I'll try'em out again....more and more money..
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
Just for anyone who might want to know, here's a quote from a PM I sent 84customZ28;
My 1157 LED replacements have diodes built in so the flasher doesn't get confused. You have a couple options, you can load the circuit with a diode, or get an electronic 552 flasher module that's for "variable loads". You may find them as "Heavy Duty and Towing" untis that will accomodate various loads including the very little load of an LED.
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
Originally posted by 19doug90
what were the specs of the led's you used?
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
I bought the 194's at Allied Auto Parts for the turn signals.
They didn't light up the whole light area and the bulbs were 1/4 inch taller than the stock ones. Couldn't secure the back of the bulb socket because the LED's hit the top of the light cover and would not "give" enough to secure the socket to the light housing.
I took 'em back.
I like the full illumination of the regular yellow 194's in the turn signals.
Jim.
I took 'em back.
Jim.
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
They changed the site I got them at around so I'm not certain which ones I got. But all you need to look for is a set/pair/whatever with a built in diode.
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
what the heck is a built in diode?
The End.
Car: 1990 Camaro
Engine: 355ci
hmm well heres my issue, i just bought some normal LED's off e-bay and they dont have a built in diode. Is there any way to wire something up that would achieve the same effect?
EDIT: let me be a little more specific, im actually doing some custom stuff and fabricating my own strip of led's in a custom bracket and was hoping to use the wiring for the stock lights. What can i do if i dont have LED's with a built in diode so i can use the wires.
Engine: 5.7
I'm just going to install those equalizers and I will be set
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
Engine: 5.7
well..I installed the "equalizer" and the LED...but still...no flashing....just stays on. I would be happy to do what TPIROC suggets...but..this LED stuff is getting very old...I'm just going to send everything I ordered back..(even though there is a 20% re-stocking fee) I wish they just made LED turn/parking light bulbs to just plug-n-play.....
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
I don't know what to tell ya man, that sucks. I just bought the friggin' things, and put them in - that's it. All I was sure of was that they had the diode. Otherwise it's really not that difficult to replace a 552. I understand the frustration however.
MikkoV
Sep 9, 2015 04:25 PM
