Ram Air 2 hood Fitting Issues?
Car: 1989 Pontiac Firebird Formula 350
I have had my Ram Air hood on for a while now but it has been quite cold so I have not had any time to really work with it until today. I am having problems with the hood sitting up to high on the drivers side. Here is a pic of how it sits on the car.
I got to looking at it and thought it was resting on the windshield washer bottle so I pulled it away and shut the hood and it still sat the same. I know it is resting on the screen around the windshield wipers but wasn't sure about up front until I really got to looking.
I found that it is sitting on the radiator shroud on the far end. It isnt the best pic but you can kind of see where it has been rubbing on the shroud. There is a spot that sticks out little bit and you can see where the paint has rubbed away.
And here is where it is rubbing on the hood.
I had a friend look at it and he suggested just notching out the area on the hood so that the part on the shroud will tuck up in there and lower the hood.
Does anyone else have any other suggestions as to what I should do?
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
my hood sits the same way(stock firebird hood) i just sat on the hood above the hinge and jumped a bit to make it fit...it still sticks up but not aas bad...but ill worry about it when i need to
Originally posted by nolanr0413
i dont know how to fix the hood not fitting like that bc i had the body shop do that , but my hood rubs in the same spot as yours.
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
I enclosed a pic of exactly where my hood was hitting. I put paint on the hood where the rub mark was, and this is where it left paint, so I banged it down on both sides, then lowered my hood latch to the lowest spot, and lowered the hinge rests lower, and mine lines up better now. If u'r not familliar with them the hinge rests are bolts that have a round rubber boot that sticks up near the back side of the hinge, pop the rubber boot off and lower the bolt to lower the back side of the hood. Worked good for me, good luck.
I have those bolts at the back of the hinge as far down as they can go. I may have to take the rubber boot off and leave it off. Was yours rubbing in the front at all where mine was or just in the spot that you marked?
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
take a hammer and knock down that high spot where it rubs, do it on both side and it will fit better, do a search and you'll find results. This question has been asked a million times.
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
The questions been asked a million times because these hoods simply SUCK when it comes to quality. Its a shame too, it would be a really nice looking hood IF they ever fit right, but I have yet to see one that does without alot of unneeded work. What a waste of $600 after shipping... the company making these should be ashamed of themselves.
Car: 00 TA, 91 Formula, 89 RS
You and me both bro, I have the same problem. I have managed to get it fitting a lil' better though. I think I need to do some more "convincing" with my hammer though.
o , one other thing, when i didnt have hood struts on it, when it came back from the shop, the hood sat lower, when i put the new 82 camaro fiberglass hood struts on it sat higher. I used to be able to bottom out the latch on the car , and now i cant, so i dont know what it did it but it did.
yea i had the same problem with my hood and after a few hours of playing with it i just cute into the hood a little here and there and it fit's much better now later on this summer i'm going to cover the holes with some rummer just for the hell of it you know
Car: 91 GTA
Engine: 5.0 TPI LB9
Transmission: 700R4 Auto
I was actually considering getting a RAII hood but now I am not sure. I never heard of the fitment issues until now. Isn't there a couple companies that make this style hood? If so is one better than the other? Thanks.
Car: Black on Black 1989 GTA
Engine: 5.7L Vortec TPi
Transmission: 6 Speed T56
Axle/Gears: 3:73
Did anyone try removing there hood spring and using an Augr to grind out the hole in the hood hinges so that the bolts that hold the hood to the hinge can be pushed lower, there for solving your hood line problems. By grinding the bolt holes in my hood and removing the hood spring I was able to obtain a perfect fit. I will post pics as soon as I paint the damn thing. Good luck guys.
I did modify the bolt holes in the hinge and got it a little better when I put it on but after I got it painted, the friend that painted it for me looked under the hood and on the hood where it rubs on the radiator shroud, you can see in the pics that I posted first, he grinded it down and it fits a hell of a lot better. It could still use a little more but I am really pleased with it now. You can try this as well to get it to fit better. I will get some pics of what I am talking about if anyone wants to see them.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
