Third Brake Light delete on wraparound wing (LOOKS GREAT)
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
This looks great !!!!!!
I've never thought that till i saw it !
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
That setup is stock for the 85/86 Trans Am with aero spoiler. The car in the picture is IIRC an 89 that was converted. The 3rd lamp has a couple 10mm screws that hold it onto the spoiler, then a few more that hold it onto the deck. You can duplicate this look by taking off the spoiler, removing the lamp & housing, filling and painting the decklid, and reinstalling the spoiler on it. I did this on my car as I used a GTA hatch and an 86 TA wing when I first painted it. I have switched out the decklid and spoiler, as well as cut off the wraparound mounting clips sience then though. Hope this helps!
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Actually I am with you on this one. I like it without the third brake light. I hated it back in the eighties when I started seeing all kinds of crazy third brake lights on the cars. I never liked any of them.
i hate third brake lights with a passion, they look so gay , im glad i have an 85 and dont have one, and the 86 is the worst with the light right in the middle. Yeah that spoiler would be stock if it were on an 85 . but none the less it looks good.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
but the other ones suck.
i drove a friends 91 hardtop Z...
looking in the rearview, all i saw was 3rdbrake light, and wing... and dont get me started on that B billar blind spot
Hey, that's my car!
Yes, it's a fiberglass replacement spoiler. It has the tapped holes in it to support the brake light but I had the bodyshop seal up the holes when I had the car painted. I'm happy with the way it came out..
Car: 02 z28, 03 wrangler sport
Engine: ls1, 4.0L
Transmission: t56, 4speed auto
if i have an 86 spoiler like that can i take the break light off the top of the hatch or are there going to be holes in the glass where bolts should be?
Engine: ls1, 4.0L
Originally posted by Steve89GTA
The trunk lid will need to be bround down and filled
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Originally posted by kamaroirock
its an 86 so it mounted on the glass so im assuming there are going to be two holes in the glass it i will need to plug
Engine: L98, Hemi 6.2
Its soo damn annoying Thread
