further adventures in polishing . . .
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
I had such good results restoring my t-tops to like new condition. I figured I'd go ahead and see what i could do about my taillight covers and center emblem as these areas (co-worker bustin my chops) are usually neglected.
before . . .
after . . .
yeah, the tailights came out just as good ! -- but, i figured there were plenty pics of pretty taillights already . . .
~ alex
before . . .
after . . .
~ alex
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
did you use the same process you used on your t-tops? where do you get the 3m plastic cleaner and polish? Last edited by Zrated83; Jun 9, 2004 at 02:43 PM.
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Damn Adam!!!! Those are SWEET!!!!
When the tail lights and turn signals are shining (I.E. Brand new looking) it really improves the appearance of the car.
:hail: Polished tail lights :hail:
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
did you use the same process you used on your t-tops? where do you get the 3m plastic cleaner and polish? 1. no neoprene block needed . . .the contours of your hands are just whats needed for the gently curvature of the pieces.
2. no sandpaper needed -- micromesh is much better to work with, and reusable !
3. the relatively small size of the lights and center make it doable in the kitchen sink, or wash basin.
4. a little dish soap goes a long way to clean as we polish.
-- I found the professional 3M plastic cleaner and plastic polish at my local NAPA.
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Originally posted by omcrider
Wow great job Alex, hey your not far off we should touch base sometime I'm in Oakland.
hehehehehave you checked out the designs for the norcal thirdgen logos im currently workin on ? havent seen you on that thread.
Car: 1988 GTA
Engine: 5.7L/L98
I saw that post, last I read into it you hadn't submitted anything yet though so I responded to your artwork and the GTG on the other post. Why unfortunatly do you work weekdays? Don't we all work weekdays? Or was it unfortunate that you work in Bezerkly?
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
. . . no, nothing against work . . . it's Bezerkeley that doesnt work for me . . . silly place . . .:lala: Last edited by adambros; Jun 9, 2004 at 04:21 PM.
Car: 1988 GTA
Engine: 5.7L/L98
Yeah theres something about that town that makes people strange, must be the water. As far back as the 60's the politics and people have had a passion for the absurd.
So back to the topic of this post, did you do the tail lights with just the micromesh? Is it possible to do them with just the fine sandpaper kit and the polish, or is the Micromesh the trick in it all. Don't have T-tops but I really like the way your center section came out and mine could use some shine restored.
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
you made me realize now that i didnt even use sandpaper for this job . . . so yeah, the micromesh is the trick.
i made the discovery, sometime ago that the 1500 grit micromesh (the lowest grit in the kit) is equal to 400 grit wet/dry paper . . . and once you work with the micromesh, you'll wonder why you ever used sandpaper.
also -- dont throw the micromesh away, its reusuable.
i went ahead and just started with the 1500 mesh and worked my way up to the 12,000. And, to be completely honest, I dont even know that the 3M cleaner / polish step makes that much of a difference. If you work up to the 12,000 grit mesh - its a mirror either way. I just get kinda obsessive about my bird -- and had a good amount left after buffing my t-tops.
Might sound stupid but here it is:
How do you polish? Wash off the peice to polish, then use it like wax but use a buffer wheel on a drill or buffer??
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
the micro mesh i found online here . . .
Steward-MacDonald Finishing Supplies
the Professional 3M cleaner and polish was at my local NAPA auto parts store.
The 3M cleaner and polish directions are simple : using a soft clean cloth, apply a quarter size drop and rub in circular motion until dry -- buff out with another soft clean cloth. Its just that easy!
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
That looks awsome good job. I've been meaning to polish mine, but I have the 82 style lights with the "ribs" on them that I don't have a nice flat area on them I could really do well. Has anyone polished their early style Firebird lights with good results? If so how did you do it?
Car: 86 iroc
Engine: 350 carbed
Transmission: t5
well just ordered my micro-mesh hopefully my stuff comes out as good.adambros are there limits on what you can use this on i was thinks of trying it on the plastic over the gauges in the dash.someone should do a test,one tail light with the polish like many others are doing and one with the micro mesh to see which one comes out better. Mods you should sticky this one too as with this method there is less risk of damage i.e. no heat build up like with the polish wheels and if you can't use sand paper evenly you shouldn't be doing either method (not that there is anything wrong with that) just my 2 cents
redtail
redtail
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
I've read that the intended use for this stuff is actually to clean, clear and polish aeromotive plexiglass. . .like windshields on passenger airlines. Im sure a few swipes with lowest grit would remove any cloudiness from the plastic cover over your gauges.
and -- I actually tried just polishing my t-tops before I went to the micro-mesh . . . no comparison. The polish restores the gloss, yeah, maybe even hides a few of those shallow scratches. . . but theres no way polishing could remove the deep scraches, pitting, and restore the optical clarity of the tops like the mesh does.
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
Stunning results !
I have some small scratches on my tail..Im gona give it a try
I found a supplier that sells the sheets for 2.49 each :Micro Mesh Singles
Car: Trans Am "GTA"
I got the micro-mesh & polished the tailights, but I still see some little scratch lines. Can barely see them, but they are there. Im thinking is the polsher I used... is the Mothers plastic polish. Should I ge the 3M, or am I doing something wrong?
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
first off if the scratch pattern, as faint as it is, is uniform -- that just means you haven't used a high enough grit yet . IIRC I went all the way up to 10000. 4000 should look like a brushed finish, 6000 satin finish, and by 8 or 10000 the scratch pattern should dissappear.
-- but, if the scratch lines your talking about are random and only appear in a few places then most likely, what happened was that you proceeded to the higher grits without making sure all the deep scratch lines were smoothed out. The only way to take care of this is go back to a coarse enough grit to remove the deeper scratches and work your way back up.
The plastic polish really doesn't do much after you work the piece over with 10000. Its more for addt'l protection, and shine. It may fill in the scratch lines some, but that's not what I use it for.
cooltc2004 -- I started with the 1500 grit micro-mesh, which as you will see is about equal to the 400 grit fine wet/dry stuff you might find in sears or at your local auto shop.
bigjay89gta
Oct 15, 2015 08:04 AM
