lost some serious weight. not she sits higher in the front
my car dont sit right now. I took a lot of weight off the front of her and the gap is twice as big now in the wheel well. I put on the fiberglass hood, removed emissons, A/C, stock pulleys, and brackets, switched to aluminum heads, and a few others things here and there. I hope she settles down once I take her for her maiden voyage. Maybe she just sit a little high since the car has been jacked up in the air for 9 monthes and now that she back on the ground the suspension just needs to be moved around a little.
Car: 82 Camaro Z28
Engine: Long Rod 383
Transmission: 350 with 3300 stall converter & 4.10 gears.
very nice look-N car..
My car also raised up in the front when i did my weight removal.........
It's starting to settle back down, but it's still not back to the same height it was before........
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
It is going to set higher than before but should settle down a bit since you had the suspension sagging all that time it has to settle back into place.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You are going to half to cut a half coil or so. The springs will not settle any more than a tiny bit if they are new. It will take a very long time for them to wear out and sag. They were desinged to have much more wiehgt on the front end. You are probably upwards of 100lbs lighter than stock.
since i whacked out around 110 pounds off the front so far, I too need to take the suspension back apart and cut off half a coil, reinstall and try it out again. Right now my caster(or is it camber....i'm tired) makes the tires look like the tops are pointing out since I've gutted so much, including the power steering, A/C, front sway bar, etc etc and the impact bar has been lightened and braced slightly as well. Front sits higher by about an inch now at least. Putting on the 165R15 tires helped lower the front back down...25.33 height compared to 26" factory tire size, but the wheel gap is horrific. Time to start chopping, and this is before i put in a tubular crossmember this coming winter as well.
Car: 1990 Chevrolet Camaro RS
I agree, I did the same weight reduction and had to finally cut the springs to get it to sit down where I wanted it.
Street Lethal
04-30-2019 12:14 PM
backtothe80s
09-05-2015 12:39 AM
