does this sound stupid???
Old Oct 3, 2000 | 10:00 PM
camaro 22's Avatar
just thinking about if this would work, and/or would it be stupid. would there be a way to remove the t-bar where the interior light is. like make it removeable with the t-tops, so it's fully open like vetts. maybe by using pins or something like that, and put the light on the back cross bar above the back seat? as for the headliner, have a plastic abs one so it looks good as well. what do you guys think? just a thought.
Old Oct 3, 2000 | 10:06 PM
Andy89RS's Avatar
If you did that you would need some serious chassis stiffening. Without it your body would as stiff as a wet noodle.
"Racing is life. Everything else is just waiting." - Steve McQueen - LeMans
305 TBI, T-5. 15.4@92 mph
Member Southern California Third Gen F-Bodies
AOL IM: Andy89RS
Old Oct 4, 2000 | 12:58 AM
AmorgetRS's Avatar
Yes, you need some serious chassis strenghtening. But no more then a convertible has. Anyway, it's not a bad idea, but I would suggest doing it this way: Take the two t-top latches and remove the glass/plastic clear part from them and get a piece of smoked glass or plexi that would fit to the top of the car and would run all the way across, then get a body saw and cut out the t-bar. Then just get some sort of generic seals and seal it all up good.
I thought about doing it to my Firebird, then decided to go to a 'Vert.
Later,
RS
Old Oct 4, 2000 | 05:19 AM
Firechicken92's Avatar
What if you made the T-bar removeable and got some acrylic t-tops and attached them to the t-bar with hinges so they will fold up together. It will keep the original appearance when its on but it can be removed all in one piece. It's not something I would try but it would be pretty cool if you can accomplish it.
92 Formula 5.7 T-tops
Flowmaster 80
Other secret mods.
Old Oct 4, 2000 | 09:24 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
That is exactly what I want to do to my T/A, make a one piece removable top. Just need to really stiffen up the body so it doesn't break down the middle.
Zepher
'86 Pontiac Trans Am WS6, 5 Speed:
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Recaro Seats,
Alpine CD+Changer,Rockford & Soundstream Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
WS6 Trans Am
Old Oct 4, 2000 | 09:25 AM
Pino91Formula's Avatar
they have allready been done , 82 Z28 and trans am i think they where done by an outside company,actually if you have ever seen Simon & Simon they drove a RED Z28 with the Targa top.
Old Oct 4, 2000 | 10:49 AM
scauffiel's Avatar
Yeah, I thought of doing this - especially when I had my hatch removed for painting. If you were to throw a notchback on there, then "targa-ize" it by removing that t-top center piece it would look completely ****.
Steve
Old Oct 4, 2000 | 02:35 PM
Mike 25th's Avatar
I got an easy way to stiffen up your car - weld the doors shut! Then you can hop in out like the Dukes of Hazzard. I've seen way to many factory convertibles sag to the point where the doors won't open correctly. I wish it were a lot easier because I would love to open up the roof on my hardtop, but I refuse to comprimise the integrity of the car. My buddy and I made a convertible station wagon before. Needless to say, it didn't last to long after that!
92 Z28 - 5.7 - Black/Grey Leather
Macewen White Faced Guages
SLP T-RAM, 24lb/h Injectors
Accell 52mm Throttle Body
SLP 1 3/4" Headers and Cat Back Sys.
My T-Rammed L98
Old Oct 5, 2000 | 09:55 PM
camaro 22's Avatar
how would you go about making the body stiffer? just some types of rods or something under it? how stiff you you have to make it exactly? i would really like to do this and am considering it.
Old Oct 6, 2000 | 06:00 AM
85cam's Avatar
Car: 92 RS
Engine: 396 sbc
Transmission: t5
Sub Frame connectors is one way to stiffen up your car, or you can weld in a roll cage but that would look dumb if you are not racing your car!
3" custom FloPro Catback
14X3 K&N open element
15.6 best 1/4 mile before any mods
Old Oct 7, 2000 | 03:52 PM
PopaPork's Avatar
Hey I am likin this Idea. I actually thought of it long time ago, but never did anything about it. But all this talk of "stiffing" it up scares me. Whut the heck would I have to do to accomplish that?
Old Oct 8, 2000 | 08:32 PM
camaro 22's Avatar
would this affect the windshield at all as far as it being held up. like the weight of it. also, how are the convertibles braced underneith different, as from the t-tops?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
djmarch
Oct 2, 2015 10:41 PM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
