Using a Wire Wheel on Aluminum Wheels
Old Jan 12, 2005 | 02:45 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
I have a set of 92 RS wheels, and I was using a 6'' grinder with a wire wheel to round the edges.
Is this a good idea? it can eat the aluminum away quickly, but do you think it will be alright and look normal if I round them all the same?
has anyone done this before?
thanks for the help!
Kyle
Old Jan 12, 2005 | 06:36 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
any one? c'mon guys!
Kyle
Old Jan 12, 2005 | 07:16 PM
megaracerx's Avatar
i dont see why not, as long as you make sure not to over grind
Old Jan 12, 2005 | 11:12 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
the way its been working for me, it will only take soo much off the edges, but yea, you have to be really careful.
I was just hoping someone else has done this before.
thanks,
Kyle
Old Jan 13, 2005 | 12:38 AM
82knightrider's Avatar
Transmission: TH200C....700R4
I used this on my 14 turbos and got a lot of caked on brake dust off
Old Jan 13, 2005 | 02:33 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
the wire wheel I used is more aggressive and takes more off
Old Jan 13, 2005 | 04:11 PM
thats the best one I found to fit in all the crevices of my 82 14 inch tubos
Old Jan 13, 2005 | 10:49 PM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
I also used a wire wheel to clean up 15" bird wheels. Just shop around because there are "coarse" one and "fine" ones... If you follow up with the fine wheel then hit it with progessively finer sandpaper, you will be amazed at the results.
POZ
Old Jan 13, 2005 | 10:52 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
yea, I almost have one wheel done(with the wire wheel anyways )
I've just gotta do some sanding then on to polishing...
I'll try to get some pics!
Kyle
Old Jan 13, 2005 | 11:04 PM
tornado's Avatar
Car: 1987 Z/28
will using wire wheels like the one 82knightrider has, scratch up aluminum wheels to much, because iam planing on polishing my wheels and i wanted to use a wire wheel is the a good way to start??
Old Jan 13, 2005 | 11:32 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
if you use a finer bristed one, it won't be that bad, when I first started mine, I had a really aggressive wheel, and it scratched the hell out of mine, but I got it smoothed out with some sanding paper and a lighter wheel.
Its great for taking the clear coat off!
But like megaracerx said, don't take too much off.
Kyle
Old Jan 14, 2005 | 12:04 AM
tornado's Avatar
Car: 1987 Z/28
so it wont scratch up the wheel to bad, will the scrath's it makes be easy to polish out???
Old Jan 14, 2005 | 10:40 PM
thepoz89's Avatar
Engine: 350, 355
It is a double edged sword, the more you use the wheel, the more you will sand. If you need to remove clear coat, use wheel sparingly...
POZ
Old Jan 14, 2005 | 11:17 PM
tornado's Avatar
Car: 1987 Z/28
ok thanks man
Old Jan 15, 2005 | 12:10 AM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
Remember to only use brass wire wheels on aluminum. They wont cause discoloration.
Old Jan 15, 2005 | 10:41 AM
RebelRacer's Avatar
Car: Bitchin' 92 RS
i've been using steel and it lookas fine...
brass just won't take as much off.
Old Jan 18, 2005 | 01:11 AM
thepoz89's Avatar
Engine: 350, 355
I used a steel one too and had no problems with discoloration...
POZ
Old Jan 21, 2005 | 02:46 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
i've almost got 3 ready to sand and polish, will get pics when I get home from school!
Kyle
Old Jan 21, 2005 | 08:29 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
they might be good for rough aluminum but i wouldnt take a wire wheel to my rims .
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Mar 18, 2019 08:29 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kah992
Aug 19, 2015 02:55 PM
