Underbody pictures?
Old Feb 22, 2005 | 03:45 PM
88CAMARO--3's Avatar
Car: 88 Camaro <--hope to get a new one soon!
Underbody pictures?
im looking for some under body pics of a camaro. also does any one have a four link suspension? or torque arm setups? if so any pictures? thanks
Old Feb 23, 2005 | 01:16 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
heres a firebird i saved from somewhere on this site a while back
Old Feb 23, 2005 | 02:02 AM
TTA-Matt's Avatar
Car: 89 Turbo Trans Am Pace Car
Engine: 3800 turbo
no sir, that's no ordinary firebird. it's a turbo trans am.
yeah!
btw, if it may help you, some underbody pics of my tta.
link
the text is in german
matt
Old Feb 23, 2005 | 02:15 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
Great underbody pics, but what's the big blue thing in this pic above the steering on the right side of the pic.....(might be purple, I'm colorblind.... .......seriously...... )
It looks like a remote oil filter, or is it a trans fluid filter????
It just stood out in the pic for me.....
Old Feb 23, 2005 | 07:43 AM
vortech305's Avatar
Looks like a remote oil filter so he could fab long tube headers.
Old Feb 23, 2005 | 09:28 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
that's a turbo buick motor, i am going to assume that it's the place the oil filter goes on those motors.
Old Feb 23, 2005 | 12:39 PM
TTA-Matt's Avatar
Engine: 3800 turbo
correct: oil filter.
Old Feb 23, 2005 | 07:08 PM
crazyn8's Avatar
Car: 55 Chevy (the only one that counts), 80 TA, 85 TA, 87 FB
Engine: BBC, BBC, SBC, none
Transmission: M-22, TH400, TH350, none
I got a 4-link on my bird. Ill get you a pic tomorrow.
Old Feb 23, 2005 | 08:41 PM
911rsq's Avatar
Transmission: yes
Hey........haven't seen you on here forever there N8!!!!!
Old Feb 24, 2005 | 03:29 AM
1320 Right Ln.'s Avatar
I'm using an S&W set-up, the torque arm attaches to the SFC's...
Attached Thumbnails Underbody pictures?-c-documents-settings-owner
Old Feb 27, 2005 | 11:49 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
where did you get that setup?
Old Feb 28, 2005 | 12:47 AM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
S&W Race cars.
Old Feb 28, 2005 | 03:33 PM
IROC_5796's Avatar
Originally posted by KEVIN L.
S&W Race cars.
looks kewl, real mean. do you have a link to where I can buy this.
Old Feb 28, 2005 | 06:36 PM
Car: FBODYS
Engine: ALWAYS 8'S
I always look in the Drag racing forum on this site to find it (the Link). I don't have it saved anywhere.
Old Feb 28, 2005 | 06:45 PM
Car: FBODYS
Engine: ALWAYS 8'S
www.swracecars.comEnjoy!
Old Mar 1, 2005 | 05:50 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Still in the process of removing the undercoating!
Attached Thumbnails Underbody pictures?-c-documents-settings-administrator
Old Mar 1, 2005 | 05:31 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
Hey ScottM where did you get those tail pipes. I kinda like the hidaway look. And I need some pipes for my new magnaflow muffler. thanks.
Old Mar 1, 2005 | 06:11 PM
rsn932's Avatar
i believe those are the stock tips
Old Mar 1, 2005 | 06:43 PM
scottmoyer's Avatar
they are original equipment.
Old Mar 1, 2005 | 09:12 PM
This has already been covered in other posts, but i just wanna warn you that if you decide to pick up this set-up, then you'll run into ground clearance issues. My dad ended up modifiying the crossbar so that it wouldn't hang down so low, and i ended up putting the stock springs back in... which we were thinking about doing neway for more weight transfer at the track.
There's other things to be careful of with this system, just wanted to give a heads up b4 u decide to buy it, be prepared for minor fabrication/modification.
Old Mar 1, 2005 | 10:41 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
seen before but.. yay!
Old Mar 1, 2005 | 10:44 PM
nick418's Avatar
Engine: L98, Hemi 6.2
Scott how do u remove the Undercoat?? also did u remove your coatin on your wheel wells?? thanks man
Old Mar 2, 2005 | 12:28 AM
mw66nova's Avatar
Engine: 7.0L
any idea if my exhaust would fit under that subframe connector/torque arm setup? that is very interesting. i kinda like it. i already have a set of Jegs SFC's, but i could take them off or modify them to work with the S&W kit if my exhaust will work with it
Old Mar 2, 2005 | 02:56 AM
No, as it is right now that exhaust will not clear. the crossbar for the SFC's is right where your piping sits. In the picture, the right side is the front subframe, and the front point of attachment for the SFC's is at the four bolts for the trans crossmember/mount.
Old Mar 2, 2005 | 06:41 AM
scottmoyer's Avatar
I used mineral spirits and plenty of rags! That's why I haven't done any more since. The only undercoating I'm removing is the yellow/brown beeswax style undercoating. It makes the undercarriage look nasty. The original black from the factory is still on the car. It can still be seen on the gas tank. The wheel wells are still with GM black also.
Fronzizzle
Feb 9, 2017 09:31 AM
TheExaminer
Sep 28, 2015 02:28 PM
Linson
Sep 21, 2015 01:08 PM
okfoz
Sep 17, 2015 10:30 AM
Strick1
Sep 6, 2015 02:21 PM
