Can I remove the door mouldings myself easily?
Old Sep 14, 2005 | 03:25 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
For those who have removed your door mouldings, what did you need to use? Did you just scrape them off with a putty knife or something? I really like the way the cars look with out them. I never really noticed people were doing it until it was pointed out to me. thanks a lot.
Old Sep 14, 2005 | 03:31 PM
Gecz28's Avatar
Car: 88 iroc vert
yea you should be able to remove them rather easily. there will probably be some glue left over. scrap it off with a putty knife and maybe some gas/laqueor thinner?
Old Sep 14, 2005 | 03:40 PM
Stevo's Avatar
Car: Pair of 92 Z28s
you might wanna re-consider that...
Your car has original paint right?
You pull off the moldings and your gonna wish you didnt its gonna be a lot brighter of a color under there and then you will have a bright silver stripe down the side.
Old Sep 14, 2005 | 03:49 PM
ZZ4 86 Z28's Avatar
well, considering the dents in my doors i was going to repaint them anyways. are you sure it will leave the mark? also, i doubt the paint is original. especially since the mouldings are black and the body is grey. they should be the same. and i know a few parts were repainted. what should i do?
Old Sep 14, 2005 | 05:32 PM
Stevo's Avatar
well having seen your car the paint definently didnt look new...it could have been original paint...i mean that color and the stripes over the gfx unless they did a good taping job or put new ones on...depends how new some of the stuff is on ur car.
Only way to tell start to pull off a very small section and glance under it
I wouldnt bother unless ur actually gonna be painting the car soon.
Old Sep 14, 2005 | 05:33 PM
Stevo's Avatar
also another thing even if the car was repainted lots of times they wont pull off the moldings...
like my car i know it was repainted but they didnt take off the molding.
Old Sep 14, 2005 | 05:45 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Back to your question you can easily remove the moldings with some fishing line or even dental floss. You just "saw" the molding off.
Then use something like 3M adhesive remover or even Goo Gone to get rid of the adhesive. That's the PITA part.
Old Sep 14, 2005 | 05:53 PM
ZZ4 86 Z28's Avatar
if you look closely you can tell the stripes were replaced where they overlap on the black stripe but dont quite touch each other on the silver stripe, lol. plus, i worked in a paint shop over summer, and the moldings were always removed. i just like how the car looks without them so much. i guess i will move away a small piece, like from the fender, and just see the paint difference.
Old Sep 14, 2005 | 06:37 PM
Stevo's Avatar
good idea and good luck
i love the way the cars look without it also...it looks so much more smooth, the body lines show better.
Old Sep 14, 2005 | 08:46 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
i definitly like how it looks w/ o the guards but i pulled mine off and it pulled up some of the clear coat. so i say do what you want i like the way mine looks w/ o them on, thats just something to consider.
ktthecarguy
Jul 5, 2020 11:46 AM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
