HELP... easy ways to hold down fiberglass cowl hood
Old Dec 1, 2005 | 08:50 AM
hayford1991's Avatar
Car: 1991 camaro rs
Engine: 355 sbc
Transmission: tremic 5 speed manual
hi everyone i have a 1991 camaro rs black with silver rally stripes i have recently bought a 4 inch cowl induction hood from jegs pin on i have it on the car i used moroso hood deck pins with lanyard straps but the center part of the hood in front lifted up and i have a 1 finger gap between hood and front nose whats the easiest way to fix this with out making it look stupid... oh it has 4 pins 2 front and 2 back
plzzz help....
Old Dec 1, 2005 | 01:16 PM
UDAMON's Avatar
Car: Mazda Protege5
did you remove the hood latch? that will help a little bit
Old Dec 1, 2005 | 02:46 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Put the factory latch back on if you removed it. That will help keep the center down. If it's still too high, then you will need to move the mounted latch down to bring the hood down.
Hope that helps.
Old Dec 1, 2005 | 02:49 PM
CraZ-28's Avatar
Car: 1991 Z-28
Oh yeah, almost forgot, if you cannot use your old factory mount, your adding more pins.
Old Dec 2, 2005 | 09:18 AM
Car: 1991 camaro rs
Engine: 355 sbc
guys i removed the hood latch because the hood is a harwood pin on an is about 2 to 3 inch thick but the only part still up is the front nose between the headlights.... finger lenght it sucks... any other help will be greatly appreciated thanks to those who all posted
Old Dec 2, 2005 | 02:32 PM
UDAMON's Avatar
Car: Mazda Protege5
does it have like an inch of a lip all the way around?? cuz mine did and the first thing i did was trim it.. if not then i dunno... sorry.. pics would help though
Old Dec 3, 2005 | 04:33 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
It could just be the hood.
Old Dec 4, 2005 | 12:36 AM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 3.73
If it is a Harwood, more than likely it is the hood. I have a Harwood cowl on my Formula and it has a bit of a gap on the front, but everywhere else it fits like stock.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
LittleFranks
Aug 20, 2015 03:55 PM
mhatfield 14
Aug 15, 2015 10:47 AM
ElPaleterro85
Aug 13, 2015 03:49 PM
