Valve Cover Suggestions
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
I am trying to decide on a set of valve covers for my motor. The heads allow me to use centerbolt or perimeter bolt valve covers which is nice.
I am running harland sharp rockers so I am pretty sure they will not allow me to run the stock valve covers.
What are people running for valve covers? I have done some looking around and I am really not prepared to spend $200 - $300 for a set of valve covers.
I would like to spend under $100 if possible. I'd like to know what you all suggest and pics of how they look.
Post em up and thanks!
http://cgi.ebay.com/ebaymotors/Cente...spagenameZWD1V
You can find these all day long on Ebay with or without the fancy milling on the top. Without milling is normally under $70. Iplan on using these too. Eventually I plan on getting some fancy high dollar pieces, but for now, those are pretty darn sharp.
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
I have always been partial to the Mickey Thompson M/T covers in the wrinkle black finish. I love the looks on the Mopars and not to bad on the sbc's either. I got a pair of the talls and they clear my Crane Gold's just fine.
Car: 1985 Camaro
Engine: 350 .030 over (355)
Transmission: 700-R4
I think summit has a centerbolt to 'standard' valvecover adapters. You can get those and then get a set of stock valvecovers and the adapters can act like a space also, plus you have a much wider selection.
Summit PN: TFS-31500811
Theyre $103 tho
Theyre $103 tho
Yah $103 is a bit pricy. My Dart heads have provisions for perimeter and center bolt so it really doesnt matter.
What I would really like is a smooth black centerbolt valve cover with enough clearance for my rockers. Any ideas?
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
get the above ones wtihout the ball milling and paint them yourself. I believe I heard somewhere that the center bolt design seals better too. Is that true?
NBrehm
Aug 25, 2015 11:49 PM
