Meguiars Cleaner wax
Old Feb 28, 2006 | 02:58 PM
jerrod75110's Avatar
Car: 89 camaro
Engine: 383
Transmission: 350 tci 3000 stall
i was wonder what everyone thinks about the meguiars 1 step cleaner wax. It says it cleans ,polish and protects in one easy step. or do you think the 3- step would be worth the end result.
Old Feb 28, 2006 | 03:06 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
The 3 step works great,not on the t/a(bad pant) but on my other trucks it took out all the swirl marks and polished it up really nice!I can't say anything about the 1 step though.
Old Mar 1, 2006 | 04:34 PM
black84z28-4spd's Avatar
i will stick to nxt
Old Mar 1, 2006 | 04:45 PM
DJCobol's Avatar
Car: '89 Black IROC 'vert
Transmission: 700-R4
Axle/Gears: 2.73 posi
Its not worth it at all. Its just thick goopy crap that fills in your scratches and swirls temporarily. If you want an off-the-shelf product, try NXT, its much better.
Old Mar 1, 2006 | 10:18 PM
Mike-in-Orange's Avatar
Car: 1992 Camaro RS
Engine: 3.1L
If your paint is in really good shape then it's perfectly fine. If have swirls and other marring you'll want something a bit more aggressive, and the three step process works pretty well. Keep in mind that doing this by hand requires some work! Also keep in mind that when using a polish you don't want to let it dry to a haze like you do with a wax - you need to really work a polish in to get any benefits, and then wipe it off before it dries. Waxes can just be gently rubbed in, allowed to haze, then wipe off. Always make sure to put on really thin layers of wax, not heavy layers that dry white enough to totally hide a black car - that's bad. Seriously, if you think you're putting it on too thin, you aren't. Use two coats.
If you really want to do it up right, wash the car, clay bar it, then do the three step. You'll love the finish.
Old Mar 2, 2006 | 05:08 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I like the Cleaner Wax too. Works for "quickie jobs". I use AstroSheild polish though. Works great, leaves and awesome shine and glaze.
Old Mar 3, 2006 | 03:18 PM
Car: 89 camaro
Engine: 383
My car was painted about a month ago. i had thought about cleaner wax then top it off with a coat of nxt. the paint is ppg with a matrix clear. any tips on waxing new paint.
Thanks Jerrod
Old Mar 4, 2006 | 07:56 AM
techno101's Avatar
Car: 1989 Camaro RS
Only a month old? I'd go with a light coat of wax, very light, if that. Your body shop should've put you a good glaze before it left. Usually lasts for a month or two.
RedLeader289
May 28, 2019 01:47 PM
zman1969
Oct 1, 2015 11:09 AM
dusterbd
Sep 29, 2015 08:40 AM
Marc Brown
Sep 28, 2015 01:40 PM
neilb
Sep 15, 2015 05:06 PM
