Dart Diecast Valve Covers on a TPI setup
Old Mar 3, 2006 | 11:43 AM
AC's Avatar
AC
Car: Used to drive a camaro
I'll post pictures tonight. So my motor is almost assembled and I'm test fitting everything before I actually drop it into the car. What I'm seeing is the alternator is in it's stock location (drivers side) and the positive lead on the back is actually making contact with my valve cover. These are taller Dart valve covers. What I was planning on doing is shortening the threaded post off the alternator and using a thinner nut. Has anyone else had this issue with Dart covers or any tall valve cover for that matter on a TPI setup?
BTW, I would move the alternator but I've also got a Procharger setup, AC delete and smog delete pulley and I don't want to start screwing with belt routings and lengths.
Old Mar 5, 2006 | 01:50 AM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
buddy of mine was running em on his 89 vert 383 vortech blown beast, i remember he had issues with it but cant remember how he solved it, i'll find out
Old Mar 5, 2006 | 02:07 PM
jerrod75110's Avatar
Car: 89 camaro
Engine: 383
Transmission: 350 tci 3000 stall
im thinking about getting some to. do the have knockouts for the pvc ?
Old Mar 5, 2006 | 03:41 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
sounds like you need a slightly longer belt to move the alternator up more out of the way. any parts store should be able to set you up with a longer serp. belt easily enough.
Old Mar 5, 2006 | 04:47 PM
AC's Avatar
AC
jerrod75110, no they don't . They do have bosses though. My engine builder charged me 50 bux to machine (3) holes. 2 breather holes and 1 pvc. Make sure you use grommets for thicker material and not the thinner stamped material. It's kinda hard to explain without a pic but the grommets you'll want with diecast material simply have a wider space on the outer diameter.
Old Mar 5, 2006 | 04:49 PM
AC's Avatar
AC
xpndbl3, I dont' understand? I can't move the alternator if I plan on using the stock bracket. Moving the alt might interfere with my blower setup / bracket too.
Old Mar 5, 2006 | 06:37 PM
xpndbl3's Avatar
Car: 1984 Z28
using a longer belt would allow the alternator to raise up the 1/2" you'd need to clear the valve covers since there's a long slot to add/remove tension onto the belt. you can even remove that bracket and add a turnbuckle setup from the hardware store for $5.
Old Mar 5, 2006 | 08:33 PM
AC's Avatar
AC
Ahhhh. I see where you were going with that. Good idea.
Old Mar 5, 2006 | 10:57 PM
xpndbl3's Avatar
Car: 1984 Z28
definately longer belt equals higher alternator which allows for battery cable clearance.
Old Mar 5, 2006 | 11:20 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
What about reclocking the alt?
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
mustangman65_79
Aug 8, 2015 01:18 AM
