Center Caps...
Old May 19, 2006 | 06:11 PM
HotRodLarry's Avatar
Car: '83 Z28
Center Caps...
One of the center caps on my '83 Z28 is a little loose. What could I use to help it stay on. Apparently two of the little tabs have broken off and the cap rattles a little. It stays on the wheel, but I don't need it to come off.
Old May 19, 2006 | 06:37 PM
Johns1989irocz's Avatar
Car: 1989 Iroc
Engine: 5.7L 350 TPI
try some epoxy
i love your sig
Old May 19, 2006 | 09:27 PM
dacboyz's Avatar
Car: 89 Camaro
I used jb weld on mine 2 years ago no problems yet.
Old May 20, 2006 | 09:39 AM
Car: '83 Z28
I tried the JB weld this morning, we'll see how it holds up. If it works, I'll put it on the other three just in case.
Old May 20, 2006 | 12:49 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
That's the only bad thing with the aftermarket center caps.The factory caps,and some repro,have metal retainer arms.The JB Weld should do the job for you.
Old May 20, 2006 | 02:20 PM
Mr. TurboTA's Avatar
I just use alittle dab of silicone on the surrounding tabs.
That way, I can remove the cap fairly easy. Clean off the dried silicone, and redo again after the cap is removed.
I don't know how easy JB Weld will come off if you ever have to remove the cap.
George
Old May 21, 2006 | 01:03 AM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
I hope you never have to get new tires....or have to get your existing tires/wheels rebalanced. Mr. TurboTA's idea sounds much better.
Old May 21, 2006 | 06:40 PM
Car: '83 Z28
I did end up using small amounts of JB Weld, just enough to hold everything together. Looks like they are still on there. Worse case scenario, I'd have to buy four new canter caps, no biggie. I have a car show coming up and I haven't decided if I wanted to run my factory wheels or my black Daytona Mods mounted with Dunlop GT Qualifiers.
Old May 21, 2006 | 07:25 PM
gon8go's Avatar
Car: 89 trans am ws6
Engine: lb9 5.0
Transmission: 5spd
Axle/Gears: 3:09
f-body motorsports sells repro ones along with nut covers.
if you really want it proper.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
Eric-86sc
Sep 28, 2015 11:37 AM
