headlight mod question
Car: '88 Bird
Engine: 2.8 V6
Transmission: t-5 5 speed
i know ive seen a few cars that at one point in their life had pop-up headlights and got those fixed. i have an 88 bird and i was wondering how i could get rid out those ugly pop-ups. are they all self fabrication or does someone actualy make them? thanks in advance for any help too.
Car: a car being parted out
Engine: blown up
Transmission: in peices
more than likely the person made them themselves.
As far as pop ups, I like them. At least now that I got mine working again!
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
A friend of mine use to have a GTA that he modified a set of the corvette aftermarket pop-up eliminators to fit his. I think he had to fab some brackets. Looked like bug eyes popping out of the hood a little. They stuck up about 1 1/2"
You have to fabricate them. There is one guy on here that has newer style sunfire headlights but that requires modifying the hood and maybe front bumper. If someone would fabricate a C6 setup that might be sweet, maybe? Otherwise, say hello to camaro.
Car: 1989 Iroc-Z
Engine: 350 tpi
Transmission: Swapped in T5
yah just search. i had a thread going from where i made some non pop ups for my 88 bird. i still have them somewhere from where i never put them on. i decided i like the pop ups better, but i got my idea from redraif. just look her up.
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Car: '88 Bird
Engine: 2.8 V6
heh thanks for all of it. i was at the wrecking yard today and was looking at the lights on a 84 camaro and it look like the brackets might be the same so im gonna see if i can fit those in there. then ill just need to caver up the top part of the light that would show. ill tell ya if it works or not tomorrow.
Car: 85 Trans Am
Our light pocket is not deep enough to mount the camaro lights. Bumper cover will cover about 1/3 of the light.
Car: 1989 Iroc-Z
Engine: 350 tpi
Car: 1989 Iroc-Z
Engine: 350 tpi
Originally Posted by 87CIZ
redraif used driving and fog lights in her conversion. I just wonder about the light output cause it looks slick
1987 Pontiac Firebird - Redraif's Pontiac "RAIF Exterior"
Car: 1989 Iroc-Z
Engine: 350 tpi
lighting was great. it wanted to do two for low beams and all four for highbeams. the problem was switching to highbeams the power that the lights were pulling was to much for the factory wiring to push so thats what the wiring kit was for. we took one off and hooked it straight to the battery and it lit up the backyard. brighter than when two were on on the car. so basically the only thing to figure out is how to get the right amount of power to go to all of them.
Car: 1989 Iroc-Z
Engine: 350 tpi
Originally Posted by casebaseball205
how much did it cost? alot of work?
