rubber wing
Old Jun 11, 2006 | 04:29 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
rubber wing
is there anything i can do to my cracked ruber wing or do i got to buy another 1
Old Jun 11, 2006 | 05:17 PM
83-ta-5spd's Avatar
strip the paint off of it, use flexible primer on it and repaint it
Old Jun 11, 2006 | 08:40 PM
89TPI350's Avatar
Car: 1989 Formula 350
Transmission: 700-R4
the rubber wing is a peice of crap. It is extremely heavy and was a terrible idea to manufacture. Throw that dang thing away and get a fiberglass one. You will thank yourself down the road because in less than a year your rubber wing will look the same as it does now if you repair it. I have seen two guys try to repair these things and they did not last at all. Once they crack and warp they are not reusable. just my
Old Jun 11, 2006 | 09:25 PM
83-ta-5spd's Avatar
yea but has an extra 350$ to buy a new fiberglass one? with the flex angent it should prevent agasint the warping and stuff, thast how im gonna do mine
Old Jun 11, 2006 | 10:27 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
My dad just redid the old spoiler on his '86. It looks great (before primer and paint). He fixed the cracks with some kind of super glue and some clamps. It may pop apart again at some point, but it was worth a shot at least. So far, he has $2 and 10 minutes invested and it looks pretty good. And before all you "just go buy a fiberglass one" guys go and bash anybody for their attempts at a repair, why don't we see exactly how his turns out. I wish I had before pics, but I will def. post "after" pics.
Besides, he bought his car for $600. It is definitely a 'fixer-upper', but it is just an 86 T/A ... nothing special. Why would he spend way over half of the car price just on a new spoiler? I figure it's worth a shot at a repair.
Old Jun 12, 2006 | 12:25 AM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
LORD do yourself a favor and get a fiberglass aftermarket...THEY ARE BEAUTIFUL and SOOOOOO light...im talking i think i atleast shed 15lbs-20lbs off the rear of the car...every little bit helps...and you nv have to worry bout that nasty cracking that will happen no matter how many times you repair it
soo many guys on here need to stop being cheap...its called saving your money...if youre stuck at mcdonalds, then go look for a better job....noone on this site is gonna obtain an amazing thirdgen or ANY CAR for $15 bucks with a 10 dollar rebate...everyone loves their thirdgen but isnt willing to spend any money on it and want everything for free or close to it and then look at camaroguy18 and kandied91z etc... and drool over there cars and wonder why their cars look like junk compared to others
Old Jun 12, 2006 | 12:56 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
U can fix the factory spoilers as much as you want.
I dont care how good they look, in time they will crack as bad as or worse than before.
ANything u do to it, doesnt fix the fact that the metal rod running thru it is rusting and swelling.
It sucks, but the only proper repair to make it last involves getting a new aftermarket spoiler.
later
JEremy
Old Jun 12, 2006 | 01:15 AM
MavViper's Avatar
Ok, so you fix the spoiler now. Down the road you will end up buying an aftermarket one anyways because the one you have now you have fixed so many times it doesn't look like a spoiler anymore. Why not save time and effort and just buy the aftermarket one now?
And no offense gcgarner, but you're going to spend a lot more than the cost that you bought it for. I haven't seen your car and dont know what condition it is in, but you will probably end up paying much more for parts than the car originally cost.
Old Jun 12, 2006 | 09:34 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
later
JEremy
Ding!
Old Jul 21, 2006 | 11:07 AM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
Why you can't repair the rubber spoiler
Alot of guys have been saying to buy the fiberglass spoiler because the rubber one will fail again. Well here is why:
THe factory spoiler is made of a metal frame surrounded in rubber. The metal frame begins to rust and swell. THe rubber around the frame begins to deform and swell also. It cracks...there is rust water running out of the spoiler when it gets wet and oozing down the side and back of your car....
You can make the outside surface look ok with work, but it WILL start bubbling, cracking, and oozing.
I just bought my 2nd $350 spoiler. It also costs around $300 to get the spoiler finished and painted. However, I put a fiberglass spoiler on my mint TTA and it looks incredible.
Old Jul 22, 2006 | 10:28 PM
gcgarner's Avatar
Seriously, if you're looking for a cheap fix, at least give the glue and clamps a try. My dad's has held up beautifully for 2 months so far in the rain and 100-degree temps.
I know you guys are all about the fiberglass (and rightfully so), but a $3 fix will work on it for at least 2 months ... I guarantee it!!
Old Jul 22, 2006 | 10:31 PM
MavViper's Avatar
And then what do you do after those 2 months? Reglueit and hope it works for another 2 months? Or go out and buy a new one like you should have 2 months earlier?
Old Jul 23, 2006 | 02:23 PM
darrells3rdgen's Avatar
Car: 86 trans am
Engine: 350 cid from a 69 chevy truck
Transmission: original 700r4
rubber wing
I have also been there, and have patched up the wing on my car 3 times now and but let me ask this
Did you know there is a piece of metal inside the rubber wing that helps give its shape?
And there are metal bolt brackets inside also where the wing bolts to the car?
did you know that the rubber wing splits and starts to fall apart because the metal inside is rusting like crazy.
I didnt know this when I fixed the wing on my car last year. but when I was standing on the go pedal and I had the car's 140mph speedo buried, I looked in my rearview mirror and quickly noticed the wing was gone!!. so of course I went back to look for it and all the while hoping any mustang owners wouldnt catch me picking up the pieces of my wing all over the highway. I knew then that no amount of glue would be able to putt the Ruber wing back to gether again.
so I you have the cash or not , take this warning that if you do patch it up and it looks like new. its still rotting inside more and more as each day goes by. save your self from the embaresment and get the fiberglass wing.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
Gordonr1973
Sep 29, 2015 11:59 AM
gta_knight
Sep 23, 2015 04:59 PM
roysatikas
Sep 22, 2015 08:15 PM
gta892000
Sep 16, 2015 12:37 AM
