will fourth gen firebird wheels fit on thirgen camaro???
Old Mar 24, 2001 | 02:34 AM
ryanretherford's Avatar
I was wondering if fourth gen wheels sixe 16x8 with tire size 245/50zr16 will fit on to my 84 camaro z 28??? if anybody has a pic of them on theirs please post.
thanks a lot,
Ryan
1984 Camaro Z-28
5.0 H.O.
Comp Cams Performance cam
Old Mar 24, 2001 | 07:48 AM
FBODY-ADDICT's Avatar
Yes they will, but you will need spacers that usually cost more than the wheels themselves. I found 16x8 fourthgen wheels for $250.00 for a set of four but the spacers I need will cost more than that according to the folks at Vette Brakes.
Buta as soon as my budget allows Ill consider that option again, I've seen those wheels on thirdgens...... sweeeet!!.
Old Mar 24, 2001 | 03:00 PM
FORD Rustangs -R- Us's Avatar
if you want nice lookin rims, try the new Grand Prix GTP wheels.. wow there nice. one problem tho..the centercap says "Pontiac" which isnt that big of a deal, but some people dont know chevy and pontiac are tight like that guess you could always repaint the center cap, but the rims are REALLY nice
Old Mar 24, 2001 | 03:17 PM
88ta_stangkilla's Avatar
will the GTP wheels fit without spacers???
Old Mar 24, 2001 | 03:34 PM
SlowCamaro88SC's Avatar
hmmmm.. fwd wheels on a rwd vehicle... doesn't sound right to me.
Old Mar 24, 2001 | 09:37 PM
89IROCZ
Guest
Posts: n/a
Correction... for 4th gen Trans Am wheels you do not need spacers. IROC, GTA, etc wheels are 16x8 and 16x8 is 16x8 is 16x8. It doesnt matter what generation, just that tehy are 16x8 and because IROC wheels are 16x8 and they fit, then the 4th gen 16x8's will fit as well.
However, you DO need spacers for 4th gen 17'' wheels..., but not for the 16's.
1989 IROC-Z
350c.i. TPI
rebuilt 700R4 with shift kit
3'' Monza Pacesetter cat back exhaust (minus the muffler)[SOUNDS OF THIS ON MY WEBPAGE]
new dual cats
3.23 Posi rear
hypertech chip
under drive pulleys
adjustable fuel pressure regulator
K&N Air Filters
Excalibur alarm, keyless entry and remote start
new:
struts, shocks, bearings, distributor, cap, rotor, alternator, battery, regulator
245 ZR16 50 Tires, Rotors and brake pads all the way around
Go to my webpage to find out more about it.
You can also see pictures, and hear sounds as well.
http://go.to/iroc-z
AOL IMer: JRShotliff
Old Mar 25, 2001 | 01:28 AM
alright thanks guys, you just helped me decide where my next paycheck is going. SLP has some fourth gen firebird wheels for $200 for the set and $549 with Z rated goodyears for anyone interested. sounds like a good deal to me. thanks again for all the help!!
-Ryan
1984 Camaro Z-28
5.0 H.O.
Old Mar 25, 2001 | 01:57 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
4th gen backspacing is different than the thirdgens. You'll still need the spacers. 2.25" in front 1.25" in back. Goto the tech article section on this site. Theres a great article there on backspacing.
just cause the rim size is the same dimensions it doesn't mean the center mounting piece is place in the same position.
[This message has been edited by Karps TA (edited March 26, 2001).]
Old Mar 26, 2001 | 03:03 PM
Pino91Formula's Avatar
YEs you need spacers for either 16" or 17" 4th gen wheels , 1.25" rear and 2.25" front spacers are needed for both applicatons
Old Mar 29, 2001 | 12:33 AM
Camaro_hunter_d's Avatar
I could have sworn the spacing was wider than that...oh well...
Old Mar 29, 2001 | 03:38 AM
Ovrclck350's Avatar
Well dammit, who makes a good inexpensive wheel for thirdgens then that doesn't need spacers???
Old Mar 29, 2001 | 03:43 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
One thing about the GTP rims is that they are 16x6 not 16x8. I was thinking of taking them off my wife's car and putting them on mine until I found that out.
'91 GTA with TPI 350 & T-Tops. Just a few mods, if you want to find out just line up next to me at a stoplight!
Added bonus:
Wife's car is a '00 Grand Prix GTP!
Old Mar 31, 2001 | 07:33 PM
Het ovrclck350 I like the ROC wheels and some centerlines too....
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
InfinityShade
Aug 22, 2015 08:00 PM
Linson
Aug 21, 2015 02:12 PM
Vintageracer
Aug 11, 2015 08:13 PM
