My wheels wont come clean???
I have the flat style turbo snowflake wheels and I cant get them to come clean. The are aluminum and have stains of some sort on them. I've tried to clean them with eagle one chrome and aluminum polish but it didn't work. I heard that that WD-40 would clean it. I haven't tried that. I also heard that ketchup works too, I haven't tried that either. What is you recommendation on clean them??
use a sos pad- I used them on my stock rims all the time and made them look brand new ( with brake stains 2 years old )and I used them once on my new rims to get some brake dust off again and it worked great!
1992 Z28 W/5.7L. Teal with unpainted cowl hood,18" Billet Specialities Rims,Eibach Sportline Springs, Leather int., B&M Mega Shifter, Headman Headers, Flows,No Cats,K&N,HyperTech air foil,Custome Burned Chip,MSD Ignition,Shift Kit, Billet Corvett Servo my Back License plate reads "ALL UL C"
Here's a pic of my car
http://www.geocities.com/jonnyarson/maro.jpg
" WHAT DOES THE BACK OF A MUSTANG LOOK LIKE "
[This message has been edited by BigMike 92 Z28 (edited April 09, 2001).]
Car: '88 Firebird Formula
Engine: 360hp/417ft. lb. 350
Transmission: Pro-Built Street/Strip 700R4
did you use any chemicals when scrubbing, or just the straight pad (the SOS)?
'88 WS6 Formula - Stock LB9
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
If you think it's stains from brake dust, try using a standard aerosol brake cleaner before taking something abrasive to them. I was very surprised to find out how well it works.
If it doesn't, you can also try a green ScotchBrite pad before heading for the steel wool ...
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
!!!!SUPER CLEAN!!!!!
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/ 100-150 Nos Wet Plate System/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Hecubus
Car: 91 z82
Engine: 5.0
TheFormula
is there a process for doing this I've been wanting to do that for some time and never had a chance to look into it
THANKS
Hecubus
THANKS
Hecubus
Another alternative you might want to try is purchasing a fairly inexpensive multi-purpose solution called "Simple Green". You should be able to get this at a store like Target or Rite-Aid for about $3.00-$5.00. I'm not sure how well it works against tough stains, but if you want to get your wheels clean without spending almost an hour (like I did today on mine :/), try that.
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
<font face="Verdana, Arial" size="2">Originally posted by Hecubus:
</font>
</font>
SUPER CLEAN sucks sh*t on these wheels....I have them! BUT.... I have come up with the solution!! Super Clean works great for CLEANING the wheel but it dulls the fu*k outta the chrome finish!! One day I super cleaned the wheels and it dulled the finish and I was p*ssed but while spraying "tire wet" on my tires I got some on the wheels and wouldn't ya know it, while wiping the wheel off it got shiny!! So I went around to all the other wheels, Super cleaned the brake dust crap off of there, and then immediately sprayed "tire wet" on the wheels and wiped it off with a soft cloth....sorta buffing it by hand!! This worked great!!
Oh yeah...since I'm thinkin' about it! Don't ever use Mequiars wax to wax your car! I sprayed some "tire wet" on my hood because I was bein' stupid and believe it or not it made my hood shine better than the Mequiars wax!! After about six months I can still tell where I put that stuff on there too and the rest of the car looks like crap again!!
Car: 91 z82
Engine: 5.0
I've been using Super Clean on my rims for over a year now and there's nothing wrong with my rims....as long as you read the back it will say it will scar or dull alunium if exposed for TOO long.
I scrub them for about 60seconds and them rinse them and nothing ever happened to them
and one of my rims has the coating comming off and it's bare alunium and still no efect there either
Works good for me
Hecubus
Works good for me
Hecubus
Dialed_In
Aug 20, 2015 01:45 PM
mdtoren
Aug 16, 2015 05:45 PM
db057
Aug 11, 2015 10:11 PM
